April 17, 2016, 17:39 |
Taylor-Couette flow
Jack Alderson Taggart Penny
Rep Power: 10 |
I am trying to solve a problem where there is a rod within a cylinder and the rod moves at a certain velocity with the help of a fluid that fills the gap between the rod and the cylinder. I believe that this is a Taylor Couette problem. I worked out the velocity of the fluid field, which is dependent on the radius of the rod and the radius of the cylinder. The velocity of the fluid field is:
u(R) = U ln(R/Ra)/ln(Ra*Rb). U is the velocity of the fluid at radius Rb. Ra is the radius of the cylinder, and Rb the radius of the rod, and the velocity of fluid at Ra equals to zero because of the no-slip condition. u(R) is the axial velocity, i.e. the fluid only moves axially, and not radially or tangentially (azimuthally). My question is quite simply this: what is the force needed to move the rod at a constant speed V. I am guessing that the answer could be as simple as F=ma? The formula above is the velocity, so I differentiate the velocity once to get acceleration and then just stick the "m" to get F=ma? Or am I missing something? Last edited by Big Kahuna; April 17, 2016 at 17:43. Reason: Wanted to make details clearer. |
April 17, 2016, 17:56 |
Filippo Maria Denaro
Rep Power: 73 |
what do you mean for constant V as then it implies a=0 ??
April 17, 2016, 18:26 |
Rep Power: 10 |
Yes, you're right. I overlooked that. But all I have been told in order to solve this problem is "What force is required to pull the rod with a constant speed U0? Neglect the end effects." It's clear that F = ma won't work here.
couette flow, laplacian operator |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Different flow patterns in CFX and Fluent | avi@lpsc | FLUENT | 4 | April 8, 2012 07:12 |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 09:33 |
potential flow vs. Euler flow | curious ... | Main CFD Forum | 23 | July 21, 2006 08:40 |
Plug Flow | Franck | Main CFD Forum | 3 | September 4, 2003 06:57 |
