No surface representation
Like Tree1Likes
  • 1 Post By davidwilcox
Old   April 15, 2016, 14:23
Default No surface representation
EOINQUIRKE is on a distinguished road
Hi guys
Im hoping somebody might be able to help me out with a basic enough meshing problem. I imported in a cad file of a plug flow reactor for the saponification of ethyl acetate reaction. When I try to run to run the mesh the program tells me that no surface representation is available for meshing. Any help is appreciated.
EOINQUIRKE is offline   Reply With Quote
Old   April 20, 2016, 00:23
david
davidwilcox is on a distinguished road
what mesh generation package are you using? in any case, you need surfaces for a 3d geometry. I would normally export my geom files as *.ACIS or *.SAT format. IGES too
davidwilcox is offline   Reply With Quote
Old   April 20, 2016, 04:30
Hi David, thanks for your reply. I am using the thin prism layer polyhedral mesher, tthe geometry files were given as CAD files, how do you import in the other formats
Old   April 20, 2016, 04:34
david
if it is a CAD file, it should be in some readable format that most CAD softwares are able to process. Use autoCAD or Solidworks for example and save the file as a format that your mesher is able to read.
EOINQUIRKE likes this.
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
2D Representation of surface values in 3D mrurq EnSight 6 February 25, 2016 06:01
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
