contours of heat transfer coefficient
Like Tree1Likes
  • 1 Post By leasken
Old   April 5, 2016, 06:22
Question contours of heat transfer coefficient
sharath jallu
sharath jallu is on a distinguished road
Is it possible to view the contours of surface heat transfer coefficient just like as we get the contours of pressure, velocity, temperature etc in fluent?????
please let me know..
sharath jallu is offline   Reply With Quote
Old   April 5, 2016, 06:29
leasken is on a distinguished road
Yes. Choose Wall Heat Transfer Coefficient as the parameter to plot.
However, you should look in to the details behind how WHTC is calculated. It uses the temperature at the first node from the wall as the reference temperature. Often the bulk temperature is the interesting temperature to use as a reference.
Edit: Forget what I said, that is true for CFX. I missed that you are using Fluent. Sorry.
nailakaleem_2000 likes this.
leasken is offline   Reply With Quote
Old   April 5, 2016, 06:43
sharath jallu
i need to get HTC in fluent.. nd btw thank you
fluent 14 to fluent 15.
Heat Transfer Coefficient Alberto Schroth FLUENT 17 February 10, 2020 09:40
Surface Heat Transfer Coefficient CFD Post MJ1105 Visualization & Post-Processing 0 February 19, 2016 05:57
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade Karkoura CFX 0 March 10, 2011 16:35
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
