March 22, 2016, 12:32 |
Fail to converge
Jonah
Rep Power: 10 |
I'm running an air flow in a room simulation, but my solution does not converge, even to 10E-4. What can I do to improve convergence?
March 24, 2016, 15:39 |
Harikrishnan
Rep Power: 10 |
Hello.
Have monitored any other parameters such as velocity or pressure at some planes? 10e-3 continuity convergence is good enough for room simulations as there will be many recirculation areas. Check your mass balance too. Convergence is not just about achieving 10e-4 or something. Thanks and regards, Hari |
June 22, 2016, 23:37 |
is this Convergence acceptable?
uvvis
Rep Power: 11 |
khnayanar ! I also have similar simulation of air passing through a box (30X40X50 cm3) which have re circulation areas. Convergence criteria is 10-4 but solution is not fully converged. I also done imbalance analysis. Can you comment that this convergence acceptable? (pics attached)IMG_6153.jpg
IMG_6152.jpg |
10e-4, convergence, criteria, improve, rms |
Eclipse for OpenFOAM | AMahrla | OpenFOAM Programming & Development | 109 | October 8, 2017 17:20 |
Gmres fails to converge, but LU is fine | sbabbi | Main CFD Forum | 1 | April 11, 2013 09:54 |
CFX FAQ updated - my simulation fails to converge | Glenn Horrocks | CFX | 0 | September 1, 2007 08:33 |
HELP !In relaxtion factor converge is taken or not | MANOJ KUMAR | FLUENT | 5 | September 22, 2005 05:16 |
Converge problem for multiphase flow | Jen | FLUENT | 4 | July 20, 2005 17:52 |
