Pressure correction
Like Tree2Likes
  • 1 Post By FMDenaro
Old   December 23, 2015, 17:40
Default Pressure correction
Harr is on a distinguished road
Hi everybody,
I am not a cfd expert, I am writing a code that can solve the flow of a lid driven cavity. I am doing this in in-compressible steady-state, using the simple algorithm. When I inverse and multiply my pressure correction matrix with my source terms, I get a near singularity. My equations are:
P'=pressure correction.
Ap*P'p=Ae*P'e+Aw*P'w+An*P'n+As*P's+Su
Su=(density*u_w-density*u_e)*area+(density*v_s-density*v_n)*area
I do not know why I keep getting near singularity.
Any help would be appreciated.
Harr is offline   Reply With Quote
Old   December 23, 2015, 17:46
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
The pressure equation Div Grad p = q with proper BC.s leads to an algebric system that has indeed a singular matrix.
However, when the BC.s satisfies the compatibility relation, you get a solution apart from a constant value
Harr likes this.
FMDenaro is offline   Reply With Quote
Old   December 23, 2015, 18:00
Firstly thank you. Sorry I do not know to much about CFD yet, what do you mean by "when the BC.s satisfies the compatibility relation"?
Old   December 23, 2015, 18:15
Actually, this is not a CFD issue but a general mathematical aspect of linear algebra.
Consider the equation for pressure and integrate both side over the computational domain
Int [V] Div Grad p dV = Int [V] q dV
use Gauss
Int [S] n.Grad p dS = Int[V] q dV
The compatibility relation must be fulfilled by the boundary condition you prescribe on the frontier of the domain
n.Grad p = f
so that you have to fulfill the condition
Int [S] f dS = Int[V] q dV
The above relation must be satisfied in discrete sense after discretization.
Only this way, despite the singular matrix, you get one solution (apart a constant).
For further details you can see in literature, for example
https://books.google.it/books?id=lXB...matrix&f=false
Old   December 25, 2015, 19:49
Kaya Onur Dag
kaya is on a distinguished road
Hi everybody,
I am very bad at these finite volume notations to me they all are gibberish so do excuse me
is this poisson equation, is [Ap] the laplace or grad.div. operator?
you may need to set a mean for your correction pressure such as setting 1 single value manually by modifying your matrix and your source (right hand side) otherwise to my knowledge your matrix system will be under determined.
kaya is offline   Reply With Quote
Old   December 26, 2015, 05:13
In a FV formulation, A*p should be the discretization of (1/|V|) Int [S] n.Grad p dS.
However, you could find also several researchers considering Div Grad p. For the pressure equation it is not suitable to discretize the laplacian operator.
The correction to the matrix entry and to the source term is consequent to the proper setting of the BC.s in such a way they satisfy the compatibility constraint
kaya likes this.
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
Fluidized Bed: Error: Divergence detected in AMG solver: pressure correction Error Ob Mole89 FLUENT 5 April 12, 2014 10:32
Timestep and Pressure Correction Relationship in SIMPLE rks171 Main CFD Forum 23 May 4, 2012 02:04
changing the coefficients of pressure correction Noel Phoenics 1 April 7, 2009 09:54
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
