December 10, 2015, 18:55 |
Boundary conditions for windtunnel
Rep Power: 11 |
I've got a rectangular domain setup to simulate a 3/4 open-section windtunnel. What would be the correct boundary conditions for the walls that represent the open areas of the tunnel? I already tried pressure outlet conditions for the 'open' walls and the simulation failed miserably - reversed flow all over the place! I'm now using slip walls and suppressed the prism layer on them, but I'm not sure this is really correct. The inlet wall is set to velocity inlet condition. The outlet set to pressure outlet condition. |
December 11, 2015, 06:17 |
Jon
Rep Power: 13 |
The only real option with wind tunnel correlation work is to model the whole thing. You will need to include the room the jet sits in and ideally and upstream geometry you can get hold of.
If you replace the edge of the jet with a free slip wall or symmetry plane you will not get reasonable correlation. When we do tunnel correlation work the models can get huge. It's necessary to get things to correlate. Good luck. |
December 11, 2015, 07:17 |
#3 | |
Rep Power: 11 |
boundary conditions, wall boundary condition, windtunnel |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 08:30 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 10:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
