Volume of general hexahedron
Like Tree1Likes
  • 1 Post By mprinkey
Old   November 23, 2015, 11:23
Lightbulb Volume of general hexahedron
Prakash
prak_1989 is on a distinguished road
Hi all,
How to calculate the volume of a general hexahedron whose faces are of different shapes and the four edges connecting the top and bottom surfaces are of different lengths and are not parallel to each other. Hope you could imagine that hexahedron
prak_1989 is offline   Reply With Quote
Old   November 23, 2015, 16:35
Michael Prinkey
mprinkey will become famous soon enough
Originally Posted by prak_1989 View Post
Hi all,
I'm no expert in computational geometry, but there is simple formula for computing volumes of tetrahedra. I wrote a library some time ago that implemented the tet formula for volume. Then I implemented the volume of a pyramid (one quad base and four triangular faces) as the sum of the volume of two tets. Then, I implemented the hex volume as the sum of three pyramid volumes (pick three faces that all touch each other at edges use those as the base for each. Use the opposite corner as top point for all three pyramids).
This all assumes that the faces are quadrilateral--I think that is a geometric requirement. If one face has four sides, I think they all do. You can build a six-sided volume using six triangles too. The above formula doesn't handle that case. Also, these quadrahedra must have vertices that are co-planar. This is probably not the most efficient way to compute the volume of general hexs, but it is more fool-proof than directly implementing a hex volume formula using a set of eight vectors. I generally only compute the volumes as part of the initialization process, so correctness is more important than absolute performance.
FMDenaro likes this.
mprinkey is offline   Reply With Quote
Old   November 23, 2015, 18:17
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
This all assumes that the faces are quadrahedral--I think that is a geometric requirement. If one face has four sides, I think they all do. You can build a six-sided volume using six triangles too. The above formula doesn't handle that case. Also, these quadrahedra must have vertices that are co-planar. This is probably not the most efficient way to compute the volume of general hexs, but it is more fool-proof than directly implementing a hex volume formula using a set of six vectors. I generally only compute the volumes as part of the initialization process, so correctness is more important than absolute performance.
I agree to the technique of decomposition in tetrahedra... it is very simple computing the volumes by using the 4-node based formula on each tetrahedron covering the grid and then computing volumes of of more complex shapes
FMDenaro is offline   Reply With Quote
Old   November 24, 2015, 06:14
Prakash
@mprinkey and @FMDenaro: Thank you for the spark. I did not think that way...!!
Old   November 25, 2015, 03:56
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Consider the following approach:
http://www.dept.ku.edu/~cfdku/papers/1999-AIAAJ.pdf
after splitting the hexahedron faces in triangles (along the diagonal)
sbaffini is offline   Reply With Quote
Old   November 30, 2015, 08:44
Prakash
Thank you very much..!!
Old   April 16, 2018, 21:18
Sourabh Bhat
heySourabh is on a distinguished road
The method by @mprinkey is an interesting decomposition. However, probably this method will not work in case of non-convex hexahedra, as it will result in negative volumes being added. I have written a simple document at https://github.com/heySourabh/GeometryCalculations/tree/master/Stokes which provides a generic method with code. May be helpful to someone looking for this.
heySourabh is offline   Reply With Quote
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 11:58
[ICEM] Volume orientation MGF ANSYS Meshing & Geometry 2 September 19, 2012 12:55
Volume 1 has invalid topology for mapped brick meshing georgewar ANSYS 0 July 24, 2011 17:02
Cell centroid and cell volume in general, and in Fluent zmester Main CFD Forum 3 October 17, 2009 12:05
help needed about phase change Yanhu Guo Main CFD Forum 4 January 24, 2001 00:16
