November 12, 2015, 02:25 |
Flow past cylinder
Tanmay Inamdar
Rep Power: 11 |
Hello guys, I am trying to model a wind tunnel experiment of flow past cylinder in fluent. Cylinder dia is 63.5 mm velocity is around 17m/s and I am using standard air properties in fluent database. Currently I am using a transient analysis with standard k-e and first order accuracy in time with a time step of 0.02 sec. I am not getting in vortices in the down flow and my cd and cl are not showing any oscillations after few time steps. I also tried searching for some research paper for high Re flow over cylinder but I can't find a one which helps. I don't know what I am doing wrong. (I have only done a introductory course in CFD so please try to explain in simole words). Thanks
November 19, 2015, 15:57 |
Nikola
Rep Power: 12 |
You usually have to wait for some time (could be long) for vortex structures to start appearing. First order k-epsilon is very diffusive and is probably ironing the vortex structures. You could try polluting the inlet flow with some velocity profile or try switching to second order. Also, you could try k-omega SST, or even Spalart-Alamaras (1 equation model). k-epsilon is not very good at predicting the flow separation point and that is crucial for this kind of problem
November 19, 2015, 19:03 |
Alex
Rep Power: 49 |
November 20, 2015, 11:53 |
#4 | |
Filippo Maria Denaro
Rep Power: 73 |
Just to add that URANS formulation can somehow useful but if you really need a transient analysis, LES is the preferred approach. |
2D modelling of flow past a rotating cylinder | pds24 | Main CFD Forum | 1 | August 21, 2015 11:50 |
Flow past an oscillating cylinder (Strouhal number) | o_mars_2010 | Main CFD Forum | 8 | May 23, 2014 05:25 |
Flow past rotating cylinder | sam.ho | OpenFOAM Running, Solving & CFD | 4 | October 10, 2013 08:49 |
CFD help: flow past cylinder | harsha00711 | Main CFD Forum | 1 | December 24, 2010 22:19 |
meshing for flow past a cylinder | karthik | FLUENT | 1 | July 15, 2005 07:17 |
