September 21, 2015, 19:18 |
stability comparison
Rep Power: 16 |
I have used two method to solve a system of nonlinear equation, with the same number of time steps, mesh, and solver, etc. Can I comment on the stability of the two methods, based on the largest time step sizes that still produces stable results? (I know it will not be a definite proper stability analysis) - any other suggestions are also welcome.
Also, if I the results seem stable, but the CFL is no longer satisfied with the larger time steps, it is correct to take the step size at which CFL condition is not satisfied as the largest step size, even though the results may seem stable? |
September 22, 2015, 02:20 |
#2 | ||
Lucky
Rep Power: 66 |
Flux inhibitors and gradient limiters also help improve stability, by a lot, and this generally isn't accounted for. Both physical & numerical diffusion also improve stability. |
September 22, 2015, 04:41 |
Filippo Maria Denaro
Rep Power: 73 |
generally, for a convection-diffusion 3d problem, the numerical stability implies the existence of a region of stability...that is a hypersurface being cx,cy,cz, alphax,alphay,alphaz the numerical parameters..
and the Neumann analysis gives a response only for the linear case.. |
September 22, 2015, 05:02 |
Rep Power: 16 |
Thank you LuckyTran. Would another (crude) approach be to compare the time the calculations take to reach convergence?
converg condition, eigenvalues, nonlinear systems, numerical error, stability analysis |
Question Regarding Stability of Nonlinear Terms | H0T_S0UP | Main CFD Forum | 1 | January 3, 2014 04:29 |
when I use multi block the condition of stability can not be fulfilled | mostafa_khan | FLOW-3D | 2 | April 19, 2012 13:17 |
stability and number of processors ?? | sersunzo | OpenFOAM Running, Solving & CFD | 0 | June 9, 2009 12:45 |
Hydrodynamic Stability vs CFD | Ben | Main CFD Forum | 2 | October 18, 2004 03:39 |
Solving linear stability eq. | K S Chang | Main CFD Forum | 3 | January 19, 2004 17:01 |
