Buoyancy: Boussinesq approximation or temperature dependence?
Like Tree5Likes
  • 5 Post By LuckyTran
Old   September 18, 2015, 06:16
Default Buoyancy: Boussinesq approximation or temperature dependence?
Agustín Villa
agustinvo is on a distinguished road
Hi folks,
I am dealing with a simulation of an incompressible fluid, where I have natural convection.
Most of the people use the Boussinesq approximation, where they use \beta as the expansion coefficient.
But, in the case where the density (or temperature) changes a lot, this model should not be applied, and temperature dependence of density must be taken into account.
When I check the validity of the Boussinesq approximation, some people says a small density difference (ie, temperature), but never said the exact value, or a reference, or a difference that allows \Delta T \cdot\beta<1.
Mi question is if you know any criteria to choose between one of those ways?
Thanks for your answer
agustinvo is offline   Reply With Quote
Old   September 18, 2015, 07:49
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by agustinvo View Post
Hi folks,
as the approximation is based on a linear expansion, the analysis generally says no more than some degree of variation in temperature
FMDenaro is offline   Reply With Quote
Old   September 18, 2015, 08:25
Agustín Villa
Hi
in my case, in the range of temperatures I am working, the density varies linearly. So, in the case I use Boussinesq, it will be only valid, if there is a linear variation?
Old   September 18, 2015, 08:32
Hi
no, it depends on the range of variation, you cannot consider Bousinnesq if you get more than some degree
Old   September 18, 2015, 08:36
Agustín Villa
I agree with you in that, but every journal, report... they only apply it, without justifying if under their conditions it's ok to use Boussinesq or not.
Since there are not more indications about when it should be used, the ideal situation should be consider always temperature dependence on density.
Old   September 18, 2015, 12:47
Lucky
The Boussinesq approximation is limited to small temperature differences because it only accounts for the changes in forces caused by temperature/density. The Boussinesq model does not actually take into account density changes (it's nearly an incompressible fluid). If your density change was purely linear, the Bounssinesq approximation would predict the correct change in buoyancy forces and in that sense it is valid to always use the Boussinesq approximation. However, if there are density changes then the constant density assumption is not valid in the sense of the remaining terms in the continuity, momentum, and energy equations (the terms involving the convective derivative). In this sense, it is always incorrect to use the Boussinesq approximation and in general, any changes in density should always be taken into account. In other words, even if your density change was purely linear, the Bounssinesq aproximation is still invalid as it does not allow for density changes (only buoyancy force changes).
The criteria to determine the validity of the Bounssinesq approximation is therefore, to limit the temperature range to be small enough so that the density change is not significant. I don't know of a general criteria that is not subjective but it is analogous to: for what Mach number can a flow considered incompressible flow? It depends on the criteria that you are interested in studying (M=0.1 for some, 0.3 for others).
FMDenaro, konangsh, bkm and 2 others like this.
InterFoam with boussinesq approximation sinusmontis OpenFOAM Running, Solving & CFD 2 October 25, 2020 13:21
Boussinesq approximation Abdul Aziz Jaafar Main CFD Forum 19 May 3, 2019 12:00
Adding Boussinesq Approximation to multiphaseEulerFoam? dschmidt OpenFOAM Programming & Development 1 January 16, 2017 17:40
Is wall ajacent temperature equal to conservative temperature of the wall? shenying0710 CFX 8 January 4, 2013 05:03
Boussinesq approximation again Gabriel Main CFD Forum 3 May 11, 2000 10:24
