2D lid cavity problem
Like Tree3Likes
  • 1 Post By Alisha
  • 1 Post By Alisha
  • 1 Post By a_gogoi@yahoo.com
Old   July 25, 2015, 12:08
Question 2D lid cavity problem
Arunav gogoi
a_gogoi@yahoo.com is on a distinguished road
i am trying a lid cavity problem using stream function-vorticity formulation. However the c code developed stops after 8 to 10 time steps . I am attaching the code and would be grateful for suggestions.
i have tried to run the program with different values of Array siz , time step but the program goes out of bounds.
# include <stdio.h>
# include <math.h>
# include <string.h>
# define SIZE 50
// assume id=jd ... no of divisions in x axis and y axis equal
main()
int i,j,k,l,m,n,id,maxiter; // re :reynolds no,id= grid size .. assume uniform mesh
double x[SIZE],y[SIZE],shi[SIZE][SIZE],zeta[SIZE][SIZE],u[SIZE][SIZE],v[SIZE][SIZE],a,b,c;
double maxstep,shires,re,h,t,dt,w;
//char chk;
FILE *fpshi,*fpzeta,*fpuv;
void zetabc( double shi[SIZE][SIZE],double zeta[SIZE][SIZE],int id,double h); // function decleration for zeta boundary conditions
//initialising the values of shi,zeta etc..
id=SIZE;
maxstep=1000;
maxiter=2000;
m=0;
w=1.8;// relaxation factor
re=500.00;
h=1.0/(id-1);
t=0.0;
dt=1.00/maxstep;
for(i=0;i<id;i++)
for(j=0;j<id;j++)
shi[i][j]=0.0;
zeta[i][j]=0.0;
u[i][j]=0.0;v[i][j]=0.0;
//setting boundary conditions for zeta
zetabc(shi,zeta,id,h);
for(i=0;i<id;i++)
x[i]=i*h;
y[i]=i*h;
//Starting Iteration process
for(k=0;k<maxstep;k++)
for(l=0;l<maxiter;l++)
// solving for stream function for internal mesh points
for(i=1;i<(id-1);i++)
for(j=1;j<(id-1);j++)
// residual of shi
shires=((0.25*(shi[i+1][j]+shi[i-1][j]+shi[i][j-1]+shi[i][j+1]+((h*h)*zeta[i][j])))-shi[i][j]);
printf("shires %d \t %d \t %4.15f \n",i,j,shires);
// SOR
shi[i][j]=shi[i][j]+(w*shires);
// set boundary conditions for vorticity
// computing vorcitity equation for internal mesh points
{ for(j=1;j<(id-1);j++)
a=(1/(re*h*h))*(zeta[i+1][j]+zeta[i-1][j]+zeta[i][j+1]+zeta[i][j-1]-(4.0*zeta[i][j]));
b=(0.25/(h*h))*((shi[i+1][j]-shi[i-1][j])*((zeta[i][j+1]-zeta[i][j-1])));
c=(0.25/(h*h))*((shi[i][j+1]-shi[i][j-1])*(zeta[i+1][j]-zeta[i-1][j]));
zeta[i][j]=zeta[i][j]+ t*(a+b-c);
printf("zeta is %f\n",zeta[i][j]);
printf("out of loop\n");
t=t+dt; // increment time step
//computing data for u and v form stream function
u[i][j]=(shi[i][j+1]-shi[i][j-1])/(2 * h);
v[i][j]=-1.0*(shi[i+1][j]-shi[i-1][j])/(2 * h);
u[i][id-1]=1.00;
printf("after uv computation\n");
// writing values of shi,
fpshi=fopen("shi.txt","w");
fpzeta=fopen("zeta.txt","w");
fpuv=fopen("uv.txt","w");
printf("After opening files\n");
for(i=0;i<id;i++)
for(j=0;j<id;j++)
fprintf(fpshi, "%2.5f \t %2.5f \t %20.10f \n",x[i],y[j],shi[i][j]);
fprintf(fpzeta,"%2.5f \t %2.5f \t %20.10f \n",x[i],y[j],zeta[i][j]);
fprintf(fpuv, "%2.5f \t %2.5f \t %20.10f \t %20.10f\n",x[i],y[j],u[i][j],v[i][j]);
printf("write data %d %d\n",i,j);
fclose(fpshi);
fclose(fpzeta);
fclose(fpuv);
// setting boundary conditions for vorticity zeta
void zetabc( double shi[SIZE][SIZE], double zeta[SIZE][SIZE],int id,double h)
int i,j;
printf("in zeta BC\n");
//top and bottom wall
for(i=0;i<=(id-1);i++)
zeta[i][0]=(2/(h*h))*(-shi[i][1]);
zeta[i][id-1]=((2/(h * h))*(-shi[i][id-2]))-(2.0/h);
printf("zeta top and bottom \t %2.10f \t %2.10f\n",zeta[i][0],zeta[i][id-1]);
printf("finish top n bottom wall \n");
// left and right wall
for (i=1;i<=(id-2);i++)
zeta[0][i]=(2/(h*h))*(-shi[1][i]);
zeta[id-1][i]=(2/(h*h))*(-shi[id-2][i]);
printf("zeta left and right \t %2.10f \t %2.10f\n",zeta[0][i],zeta[id-1][i]);
return;
a_gogoi@yahoo.com is offline   Reply With Quote
Old   July 30, 2015, 06:24
Default Found a error!
Biswajit Ghosh
Alisha is on a distinguished road
hi Arunav,
I guess you have not set the initial condition of vorticity properly.
Though I don't code with C ( was struggling to understand it ), it seems like you have set vorticity 0 everywhere, which is not the case... in fortran I would write it like this :
DO i=0,n
DO j=0,n
IF (j==1) THEN
vorticity(i,j) = u_lid/dy
ELSE
vorticity(i,j) = 0
END IF
END DO
END DO
which means at moving wall the vorticity wont be 0
Tell me if it solves your problem...
and first try with no relaxation i.e. w = 1, it will work too... take Re = 100 for the first attempt...
Additionally I am sending the link of a pdf which I found helpful during writing stream fn vorticty code... Happy coding
a_gogoi@yahoo.com likes this.
Alisha is offline   Reply With Quote
Old   August 1, 2015, 04:42
Arunav gogoi
Dear Alisha,
i start my expressing my gratitude for your reply.
I have done the following in my code.
Before starting ,in C unlike FORTRAN for an array of a[id], the arrays start with a[0] and end with a[id-1].
Also in my code i have used zeta for vorticity and shi for stream function.
void zetabc(...) is function for setting the boundary conditions for zeta.
hence the problem of zeta is i think taken care of .
I have also tried your suggestions my i am unable to get the results.
Old   August 6, 2015, 03:11
Smile hi there!
Biswajit Ghosh
I have a small fortran code, which you can use if u wish. Just give me your mail id
Old   August 6, 2015, 06:22
Arunav gogoi
my email id is a_gogoi@yahoo.com
Alisha likes this.
2d lid cavity
Lid driven Cavity suman91 SU2 3 May 24, 2022 06:23
Convergence problem in 2D cavity problem dreamz Main CFD Forum 0 December 9, 2013 18:55
The Upper Limit of Relaxation Parameter for Lid-Driven Square Cavity Problem wtih SOR Ilker Main CFD Forum 0 January 5, 2013 11:56
Lid driven cavity problem thegodfather Main CFD Forum 1 December 2, 2012 05:37
Boundary condition for compressible flow ( cavity lid problem) pike@91 Main CFD Forum 2 June 2, 2012 18:04
