August 6, 2008, 11:57 |
what is "C grid" "O grid"
August 9, 2008, 10:35 |
Re: what is "C grid" "O grid"
Hi ztdep,
C-grid and O-grid are types of structured (mapped) hex/quad grids. As an example, consider a structured quad grid for an airfoil. In an O-grid, one family of grid lines goes around the airfoil, from the airfoil surface to the outer boundary. The other family of grid lines go radially from the airfoil to the outer boundary. Because the first family of lines go around the airfoil they are "circular" shaped like the letter "O" - hence the name. Here is a picture of an O-grid. http://www.innovative-cfd.com/images/O-grid-small.jpg For a C-grid, consider the airfoil again but imagine that a grid line exists for the wake. So the first family of grid lines starts at the downstream boundary, goes forward around the front of the airfoil, and then back out the downstream boundary. That gives them the shape of the letter "C" (if you use your imagination). Here is a picture of a C-grid. http://upload.wikimedia.org/wikibook...ca0015grid.png There's also an H-grid, but I think you can probably figure out what that topology looks like. Hope this helps. |
September 1, 2008, 01:27 |
how to construct O grid in a gambit
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 15:17 |
Grid Adaptation | Suresh | FLUENT | 0 | October 15, 2003 14:18 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 09:32 |
Combustion Convergence problems | Art Stretton | Phoenics | 5 | April 2, 2002 06:59 |
Troubles modelling flow through a grid | Hans Klaufus | CFX | 1 | June 28, 2000 17:43 |
