June 13, 2015, 12:09 |
NASA Polynomials >> UNITS <<
Tobias Holzmann
Rep Power: 52 |
Hi all,
I am a bit confused about the NASA Polynomials and the units they have. I am right with the following stuff:
or is it kcal/mol or only J/mol? Thanks in advance. PS: I think it depend on the unit of the individuel gas constant R. If I use it in J/molK the units should be like that.
Keep foaming, Tobias Holzmann |
June 13, 2015, 15:12 |
Mianzhi Wang
Rep Power: 11 |
I think you are right about the R.
If I remember correctely, they are dimensionless, e.g. h/RT, s/R, cp/R. |
June 14, 2015, 20:35 |
Jenna
Rep Power: 12 |
I believe you are correct in treating it that way. That is how I have done it, using R =8.314 J/mol-K to get Cp in those same units and dividing by the molar mass such that it is J/kg-K
A good sources for NASA Polynomial explanation is: http://combustion.berkeley.edu/gri_m...nasa_plnm.html and a list of polynomials themselves https://combustion.llnl.gov/content/...anes_therm.txt |
June 15, 2015, 03:45 |
Tobias Holzmann
Rep Power: 52 |
Dear all,
thanks for the replays and the feedback. The sites of grimech and the nasa polynomials I know Thus you showed the NASA site, can you just clear my mind about that line: Code:
H in the above equation is defined as H(T) = Delta Hf(298) + [ H(T) - H(298) ] so that, in general, H(T) is not equal to Delta Hf(T) and one needs to have the data for the reference elements to calculate Delta Hf(T). For example: If I calculate H at 298 I get H(298) = deltaHf
June 15, 2015, 11:14 |
#5 | |
Mianzhi Wang
Rep Power: 11 |
It means if you want Delta Hf(500) of water, You'll need not only H(T) of water, but also H(T) of H2 and O2 as well.
The fact that Delta Hf(298) = H(298) for any species is because H(298) = 0 for any species like H2, O2 (the most stable single-element species at reference state). Quote:
January 22, 2016, 19:37 |
Tobias Holzmann
Rep Power: 52 |
Hello Wang,
I have a question for the deltaH calculation. If I made some comparison I always have problems with deltaH (I did not get the point). For example we can check some data here: http://combustion.berkeley.edu/gri-m...cies/c3h8.html If I calculate cp(T), S(T) and "H(T)" I get this one: Code:
T: 200, 11.6896 58.7521 -26285.9 T: 300, 17.4924 64.6154 -24820.2 T: 400, 22.5544 70.3576 -22812.1 T: 500, 26.9572 75.8749 -20331.3 T: 600, 30.7775 81.1358 -17440.1 T: 700, 34.0862 86.1348 -14192.9 T: 800, 36.9492 90.8779 -10637.7 T: 900, 39.4266 95.3764 -6815.89 T: 1000, 41.5734 99.6442 -2763.35 T: 1100, 43.4391 103.696 1489.42 T: 1200, 45.0678 107.547 5916.56 T: 1300, 46.4983 111.212 10496.4 T: 1400, 47.7639 114.705 15210.7 T: 1500, 48.8926 118.04 20044.6 T: 1600, 49.907 121.228 24985.4 T: 1700, 50.8242 124.282 30022.8 T: 1800, 51.6561 127.211 35147.4 T: 1900, 52.4093 130.024 40351.4 T: 2000, 53.0877 132.73 45626.8 T: 2100, 53.6953 135.335 50966.5 T: 2200, 54.236 137.846 56363.6 T: 2300, 54.714 140.268 61811.6 T: 2400, 55.1335 142.605 67304.5 T: 2500, 55.4988 144.863 72836.5 T: 2600, 55.8144 147.046 78402.6 T: 2700, 56.0847 149.158 83997.9 T: 2800, 56.3145 151.202 89618.2 T: 2900, 56.5086 153.182 95259.6 T: 3000, 56.6718 155.1 100919 T: 3100, 56.8092 156.961 106593 T: 3200, 56.9258 158.766 112280
January 23, 2016, 01:04 |
#7 | |
Mianzhi Wang
Rep Power: 11 |
In this case: Delta h_f (T)_propane = h(T)_propane - 3h(T)_C -4h(T)_H2 |
January 23, 2016, 07:03 |
#9 | |
Tobias Holzmann
Rep Power: 52 |
Just to get it 100% clear:
h_f(T)_C2H3CHO = h(T)_C2H3CHO - 2h(T)_C - 4h(T)_H2 - h(T)_O Code:
h_f(T)_C2H3CHO = h(T)_C2H3CHO - 2h(T)_C - 4h(T)_H2 - 0.5h(T)_O2 Code:
Delta h_f (T)_butyl = h(T)_butyl - 4h(T)_C -4.5h(T)_H2 Quote:
I am right?
January 23, 2016, 19:59 |
#10 |
Tobias Holzmann
Rep Power: 52 |
Hey,
today I investigated into that problem again and with your statement I figured it out but I have still a problem. For example my calculated results are similar to that one postulated in the above link. I pointed out that its is like that: Code:
Hf(NO2) = H(NO2) - H(O2) Hf(OH) = H(OH) - 0.5 H(O2) - 0.5 H(H2) Hf(O2) = H(O2) - H(O2) = 0 (also for N2, H2, AR) Code:
Hf(NNH) = H(NNH) - H(N2) - 0.5 H(H2) Code:
b) T = 200 :::: dHf(NNH) = 59.8241 b) T = 300 :::: dHf(NNH) = 59.6058 b) T = 400 :::: dHf(NNH) = 59.4136 b) T = 500 :::: dHf(NNH) = 59.2674 b) T = 600 :::: dHf(NNH) = 59.1694 b) T = 700 :::: dHf(NNH) = 59.1105 b) T = 800 :::: dHf(NNH) = 59.0774 b) T = 900 :::: dHf(NNH) = 59.0592 b) T = 1000 :::: dHf(NNH) = 59.0538 b) T = 1100 :::: dHf(NNH) = 59.0617 b) T = 1200 :::: dHf(NNH) = 59.0763 b) T = 1300 :::: dHf(NNH) = 59.0964 b) T = 1400 :::: dHf(NNH) = 59.1212 b) T = 1500 :::: dHf(NNH) = 59.1495 b) T = 1600 :::: dHf(NNH) = 59.1806 b) T = 1700 :::: dHf(NNH) = 59.2138 b) T = 1800 :::: dHf(NNH) = 59.2485 b) T = 1900 :::: dHf(NNH) = 59.2839 b) T = 2000 :::: dHf(NNH) = 59.3198 b) T = 2100 :::: dHf(NNH) = 59.3555 b) T = 2200 :::: dHf(NNH) = 59.3909 b) T = 2300 :::: dHf(NNH) = 59.4254 b) T = 2400 :::: dHf(NNH) = 59.459 b) T = 2500 :::: dHf(NNH) = 59.4913 b) T = 2600 :::: dHf(NNH) = 59.5222 b) T = 2700 :::: dHf(NNH) = 59.5514 b) T = 2800 :::: dHf(NNH) = 59.579 b) T = 2900 :::: dHf(NNH) = 59.6046 b) T = 3000 :::: dHf(NNH) = 59.6283 Code:
Hf(C3H8) = H(C3H8) - 3*H(C) - 4*H(H2) Code:
Hf(C) = H(C) If we compare this one http://combustion.berkeley.edu/gri-m...ecies/ch3.html with my calculated one: Code:
b) T = 200 :::: dHf(CH3) = 35.2246 b) T = 300 :::: dHf(CH3) = 35.0925 b) T = 400 :::: dHf(CH3) = 35.0072 b) T = 500 :::: dHf(CH3) = 34.9932 b) T = 600 :::: dHf(CH3) = 35.057 b) T = 700 :::: dHf(CH3) = 35.193 b) T = 800 :::: dHf(CH3) = 35.3905 b) T = 900 :::: dHf(CH3) = 35.6399 b) T = 1000 :::: dHf(CH3) = 35.9392 b) T = 1100 :::: dHf(CH3) = 36.2862 b) T = 1200 :::: dHf(CH3) = 36.6695 b) T = 1300 :::: dHf(CH3) = 37.0838 b) T = 1400 :::: dHf(CH3) = 37.5241 b) T = 1500 :::: dHf(CH3) = 37.9862 b) T = 1600 :::: dHf(CH3) = 38.4664 b) T = 1700 :::: dHf(CH3) = 38.9615 b) T = 1800 :::: dHf(CH3) = 39.4685 b) T = 1900 :::: dHf(CH3) = 39.9851 b) T = 2000 :::: dHf(CH3) = 40.5092 b) T = 2100 :::: dHf(CH3) = 41.0392 b) T = 2200 :::: dHf(CH3) = 41.5736 b) T = 2300 :::: dHf(CH3) = 42.1113 b) T = 2400 :::: dHf(CH3) = 42.6515 b) T = 2500 :::: dHf(CH3) = 43.1932 b) T = 2600 :::: dHf(CH3) = 43.7361 b) T = 2700 :::: dHf(CH3) = 44.2796 b) T = 2800 :::: dHf(CH3) = 44.8234 b) T = 2900 :::: dHf(CH3) = 45.3671 b) T = 3000 :::: dHf(CH3) = 45.9105 Kind regards, Tobi
January 23, 2016, 20:14 |
#11 |
Tobias Holzmann
Rep Power: 52 |
It is already late but I think I am wrong in one case:
Hf(CH3) = H(CH3) - H(C)_solid - 1.5 * H(H2) I will check it out because in other NASA Polynomials I found that I have two entrys for C. One for the gas and one for solid. I think H(C) is always solid state due to the fact of stable phase.
February 23, 2017, 14:47 |
#12 |
Abdul Rehman Bangash
Hi Tobi,
Would you share how did you solve the problem with carbon? Regards |
Thermophysical Property Units | johanz | OpenFOAM Pre-Processing | 2 | December 16, 2018 11:08 |
therm.dat NASA polynomials | mystix | OpenFOAM | 5 | May 31, 2018 04:17 |
nasa polynomials | gardian | CFX | 3 | March 10, 2011 07:29 |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 17:55 |
NASA polynomials, thermo.dat tables | Tomislav Sencic | Main CFD Forum | 8 | December 15, 2009 11:09 |
