Looking for 3D wind tunnel airfoil(wing) experimental data for CFD validation |
June 4, 2015, 10:41 |
lz
Rep Power: 11 |
Hi all,
Currently I need to model the 3D wing for lift and drag coefficient calculations. I need some 3D wind tunnel experimental data for the CFD validation so that I can feel more comfortable about my simulation data. Where could I find these 3D experimental data? thanks!!! |
June 4, 2015, 13:53 |
Rep Power: 19 |
Try googling "ONERA M6"
June 4, 2015, 15:26 |
Matt
Rep Power: 18 |
As agd suggests, ONERA M6 is a good option. Here are some others that I have used in the past as well... Weber, J. and Brebner, G.G., ‘Low Speed Tests on 45-deg Swept-Back Wings. Part 1: Pressure Measurements on Wings of Aspect Ratio 5,’ Aeronautical Research Council, RM-2882, London, England, UK, ©1958. Hall, I.M. and Rogers, E.W.E, ‘Experiments with a Tapered Sweptback Wing of Warren 12 Planform at Mach Numbers between 0.6 and 1.6,’ Aeronautical Research Council, RM-3271, London, England, UK, ©1962 Kolbe. C.D. and Boltz, F.W., ‘The Forces and Pressure Distribution at Subsonic Speeds on a Plane Wing Having 45 ° Sweepback, Aspect Ratio of 3, and a Taper Ratio of 0.5,’ NACA RM-451G31, National Advisory Committee for Aeronautics, ©1951. Graham, R.R., ‘Low-Speed Characteristics of a 45° Sweptback Wing of Aspect Ratio 8 from Pressure Distribution and Force Tests at Reynolds Numbers from 1,500,000 to 4,800,000,’NACA RM-L51H13, National Advisory Committee for Aeronautics, ©1951. McAlister, K.W. and Takahasi, R.K., ‘NACA 0015 Wing Pressure and Trailing Vortex Mesurements,’ NASA TP 3151, National Aeronautics and Space Administration,. Washington, D.C., ©1991. Jacobs, W., ‘Pressure-Distribution Measurements on Unyawed Swept-Back Wings,’ NACA TM 1164, National Advisory Committee for Aeronautics, Washington, D.C., ©1947. Johnson, H.S. and Hagerman, J.R., ‘Wind-Tunnel Investigation at Low Speed of An Unswept Untapered Semispan Wing of Aspect Ratio 3.13 Equiped with Various 25-Percent-Chord Plain Flaps,’ NACA TN 2080, National Advisory Committee for Aeronautics, Washington, D.C., ©1950. |
June 4, 2015, 23:01 |
lz
Rep Power: 11 |
June 4, 2015, 23:04 |
#5 | |
lz
Rep Power: 11 |
Looking for 3D wind tunnel airfoil(wing) experimental data for CFD validation | Anna Tian | Main CFD Forum | 18 | June 3, 2015 23:56 |
wind turbine simulation inside the wind tunnel | shaohua | FLUENT | 4 | April 11, 2014 18:01 |
Rotate part in wind tunnel | andr3s_diaz | STAR-CCM+ | 5 | November 5, 2013 09:52 |
Wind Tunnel Website now online | Mike Worthey | Main CFD Forum | 0 | June 6, 2000 03:27 |
wind tunnel correction | Arthur Chen | Main CFD Forum | 2 | September 4, 1998 19:42 |
