Inviscid transonic flow over circular bump
Like Tree1Likes
  • 1 Post By Martin Hegedus
Old   May 17, 2015, 05:24
Default Inviscid transonic flow over circular bump
Ashwani
AshwaniAssam is on a distinguished road
Dear all,
I was simulating the inviscid flow over circular bump (10% height) for M=0.675 (transonic regime). The problem I am facing is that I am not getting a proper match for the mach number plot along the lower bump wall at downstream. The plot is attached below. I have used subsonic outflow boundary condition (Whitfield'84 et al). I am using total pressure boundary condition at inflow. The walls have slip condition. it is a density-based solver, with roe scheme. The spatial accuracy is 2nd order, with minmod and Venkatkrishnan limiter. Can anyone please help. Did somebody also got such difference?
Also, I want to ask as far as I have seen most transonic bump cases has been reported using pressure-based solver. Is that one reason for such difference.
I am also attaching the Mach contours.
Thanks for going through this post.
AshwaniAssam is offline   Reply With Quote
Old   May 18, 2015, 00:32
Martin Hegedus
Martin Hegedus is on a distinguished road
I suspect it's the numerical dissipation which is adding additional entropy. I would suggest running at a lower Mach number such that at shock does not exist. That will remove the entropy generated by the shock. Then try adding more grid points. I suspect the "wake" will disappear to some extent. However, to some degree it will always be there. To remove it you might need to go to a higher order less dissipative method.
Martin Hegedus is offline   Reply With Quote
Old   May 19, 2015, 08:52
Ashwani
Thanks for your reply. I would run the lower mach number and report for the same. We are understanding that since we are using AUSM i.e. an upwind scheme we are getting such dissipation downstream. I have ran the similar cases with MacCormack Scheme (Central scheme), there I got a better match at the downstream. Is it the something same with pressure based solver, because of which dissipation is less their?
Old   May 19, 2015, 12:02
Martin Hegedus
I'm not familiar with pressure based schemes, but how one iterates towards steady state should not effect the amount of dissipation at steady state. If the pressure based scheme uses a different discretization method, then yes the amount dissipation could be different.
AshwaniAssam likes this.
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 18:51
Transonic flow over a bump A.D.E Main CFD Forum 4 July 8, 2011 08:25
Total pressures; Transonic flow Louwrens CFX 9 April 19, 2003 19:01
Inviscid flow calculator, Entropy rise?!! MJK Main CFD Forum 3 April 9, 2003 04:36
Inviscid flow Atit Koonsrisuk CFX 12 January 2, 2003 13:40
