Ideal gas law and incompressible flow
Like Tree8Likes
  • 2 Post By mprinkey
  • 2 Post By FMDenaro
  • 1 Post By Martin Hegedus
  • 1 Post By Nick R
Old   May 4, 2015, 12:37
Default Ideal gas law and incompressible flow
Nick
Nick R is on a distinguished road
Hi guys,
I've read that when Mach is below 0.3, then the flow is considered incompressible. But in textbooks that look at flow thru a turbo jet, in the compressor or diffuser, nozzle etc although the flow is often subsonic and below Mach 0.3, they use the ideal gas law. My question is:
Can the ideal gas law be used when Mach is below 0.3? Why? Isn't the flow supposed to be incompressible?
Thanks.
Nick R is offline   Reply With Quote
Old   May 4, 2015, 12:53
Michael Prinkey
mprinkey will become famous soon enough
M < 0.3 is a rule of thumb, not a law. Compressibility effects generally scale as M^2. So 0.3^2 makes the error scale as 0.09 if you treat 0.3 Mach flow as incompressible. And, really, this is a statement about local Mach number. You can have flows with an average/freestream Mach number well under 0.3, but have high velocity areas with M>0.3 that end up being important to the overall flow behavior.
Blanco and FMDenaro like this.
mprinkey is offline   Reply With Quote
Old   May 4, 2015, 13:00
Nick
Thanks for that. How does one know when to use the ideal gas law then ? How do we know compressibility effects are important?
Old   May 4, 2015, 13:21
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
real gas are always compressible in their nature, the "incompressibilty" is only a model used to simplify the set of equations.
But if you assume rho= constant, the continuity equation becomes Div v = 0 and if you consider also homoentalpic condition T= constant that would lead to the ideal law of gas p=const. This conclusion is not correct, pressure gradients in the momentum equation still have sense to ensure a divergence-free velocity field bu you have no law for prescribing a value for the pressure depending on density and temperature.
Many researchers use the full compressible model, with the ideal law p=rho*R*T even for low Mach flows. They simply disregard the incompressibility as a simplification and retain the full form of the NS equations. At Mach=0.2-0.3 such formulations work fine, at lower Mach numbers can be necessary to use some pre-conditioning technique.
mprinkey and suktan like this.
FMDenaro is offline   Reply With Quote
Old   May 6, 2015, 21:52
Nick
Supposing we accurately measured the temperature and density fields around an airfoil in an experiment where the flow Mach number is below 0.3, would the ideal gas law provide the pressure field (the same one as that measured by pressure sensors on the foil for instance)?
Old   May 6, 2015, 22:52
Martin Hegedus
Martin Hegedus is on a distinguished road
The assumption of incompressibility does not mean that the flow is actually incompressible. However, the assumption allows for the conservation of mass and momentum to be decoupled from the conservation of energy and the ideal gas equation. So for incompressible flow, one first solves for pressure and velocity and then for temperature and density.
Edit: Incompressibility means that the density changes are small enough the the equations can be decoupled.
jxmao likes this.
Martin Hegedus is offline   Reply With Quote
Old   May 7, 2015, 01:07
Nick
I don't think you could use the incompressible continuity, momentum and energy equations and the ideal gas law together. I think either you assume compressibility whereby you solve the fully N-S equations and gas law OR incompressible flow equations without ideal gas law.
Old   May 7, 2015, 03:11
Martin Hegedus
There are six unknowns (p, u, v, w, rho, and T) therefore six equations are required. As the Mach number decreases, the compressible and incompressible equations will give nearly the same answer. What the incompressible equations allow for is the solution of p, u, v, and w independently from rho and T since the conservation of mass and momentum are insensitive to changes in density at low Mach numbers.
Old   May 7, 2015, 04:17
well, if you would have measurement of temperature and density that provides the static pressure rho*R*T; on a foil you must be aware of the type of sensor, if it measures the static or dynamic pressure (rho*v^2).
Old   May 7, 2015, 09:58
gdbb89 is on a distinguished road
The Ideal Gas Law as in the Equation of State? Compressibility doesn't dictate its use because density is in the equation itself and therefore compressible effects are taken into account. The IGL relation can be used for any ideal gas regardless of Mach number to relate pressure, volume/density, and temperature.
gdbb89 is offline   Reply With Quote
Old   May 7, 2015, 23:07
Nick
Sure. What I meant was, if we use an incompressible model, T is found from the energy equation rather than the ideal gas law. Do you agree?
Martin Hegedus likes this.
Old   May 7, 2015, 23:09
Nick
From what you wrote I understand that if the surface pressure sensors were used to measure the static pressure, it would provide the same values as those found from the ideal gas law.
Old   May 8, 2015, 04:07
compressible or incompressible model, T (temperature) is always found from the energy equation...
in the incompressible model the energy equation is simply decoupled (apart the buoyancy-driven flow) and can be solved after the continuity and momentum equations are solved.
juliom and granzer like this.
Old   May 27, 2019, 15:38
Default ideal gas or constant density
  #14
Stephen Adeoye
dehbola is on a distinguished road
i am simulating the flow of super critical c02 through a jet impingement. I am unsure in selecting the models for the gas either to use the ideal gas or constant density.
dehbola is offline   Reply With Quote
Density and compressiblity Mohsin FLUENT 7 June 7, 2015 23:23
Incompressible Ideal gas law Leverkin FLUENT 5 March 5, 2009 17:41
Incompressibility - Ideal Gas selim CFX 3 July 6, 2007 19:10
problems simulation ideal gas, divergence in AMG S Ralf Schmidt FLUENT 11 October 1, 2005 14:21
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
