Rep Power: 11 ![]() |
Dear all,
I am learning CFD and facing some issues concerning the boundary conditions. So far as I understood the boundary conditions can be implemented via two ways: 1) "Ghost" Cells, which are cells added to the BC and that can be used without much change with the discretization scheme used on the interior cells 2) Set the value at the face of the boundary cell and determine different coefficients for the general equation at the Boundary Cells. Am I right? In case so, where can I find more information about the "ghost" cells for Finite Volume Methods? All the best |
shahrooz
Rep Power: 15 ![]() |
check versteeg book, it has a chapter on boundary conditions. It is not about ghost cells but it will get the job done.
http://www.amazon.com/An-Introductio.../dp/0131274988 |
#3 | |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
Often, the two mentioned approaches are exactly the same in terms of accuracy and stability, the difference being only in the code implementation |
boundary cell |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
