April 13, 2015, 16:43 |
Numerical dissipation and dispersion
Y. Yang
Rep Power: 16 |
Hi All,
I am confused with a basic problem of CFD. When we derive the discretized formula with upwind central differencing or other scheme, the numerical dissipation and dispersion terms are used to evaluate the accuracy and stability of the specific scheme. I can understand how these terms are derived. However, the physical and numerical meaning of these terms are confusing? Why are they called numerical diffusion and dispersion? And what is their effect on accuracy and stability? Thank you Richard
PhD candidate |
April 13, 2015, 17:02 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
consider the equation df/dt + u df/dx =0 u positive constant assume f(x,0)=f0(x) a periodic wave function. The exact solution is a travelling wave at constant speed u. Numerical diffusion is responsible of the fact that the peaks (min and max) of the wave are not maintaned but diminuish in time. Numerical dispersion is responsible of the fact that packet of waves travel ad speed different from u. You cna use Fourier analysis to analyse the effects |
April 14, 2015, 05:21 |
#3 | |
Rep Power: 16 |
It seems like lower order numerical schemes are more stable due to the numerical phenomena described above. Numerical schemes of high accuracy sometimes introduce an additional artificial diffusion term to help stablilize those schemes. Diffusion and dissipation are sometimes used interchangeable and sometimes the even order terms are called dissipation and then the combination of dissipation and dispersion is named diffusion. I am happy if somebody can provide reference to a text book or expand on my explanations because I am also not sure if my explanation is correct. |
April 14, 2015, 06:37 |
Rep Power: 73 |
this is a classical topic of CFD, there are many well known textbooks (older or not) that explain the matter.
April 14, 2015, 09:21 |
#5 | |
robo
Rep Power: 13 |
My preferred references for numerical diffusion/dispersion are the textbooks computational fluid mechanics & heat transfer by Pletcher, Tannehill, and Anderson, and computational aeroacoustics by Tam. The acoustic one will emphasize spectral characteristics a lot more, which may not be useful to everyone. |
April 14, 2015, 09:45 |
Radwanma
Rep Power: 12 |
Hi all;
How can I change the magnitude of the Y+ (wall distance ) in the ICEM ??? Regards, |
April 14, 2015, 10:00 |
#7 | |
Rep Power: 16 |
thank you very much for correcting my mistake and additionally providing the literature. You are correct! :-) I will study your suggested textbooks. Best regards |
April 15, 2015, 01:52 |
Y. Yang
Rep Power: 16 |
Dear Filippo,
Thank you for your kind reply. This is very clear understanding
PhD candidate |
April 15, 2015, 01:55 |
#9 | |
Y. Yang
Rep Power: 16 |
PhD candidate |
April 15, 2015, 01:58 |
#10 | |
Y. Yang
Rep Power: 16 |
Thank you for your reply. I have collect some material that may help: http://elearning.cerfacs.fr/pdfs/numerical/FDscheme.pdf http://www.mathematik.uni-dortmund.d.../lecture10.pdf https://people.maths.ox.ac.uk/trefethen/5all.pdf Regards
PhD candidate |
numerical dispersion, numerical dissipation |
Dissipation and dispersion errors | francesco_capuano | Main CFD Forum | 6 | September 18, 2012 13:42 |
Dissipation & Dispersion | Mehdi-Sanaei | Main CFD Forum | 4 | April 24, 2011 10:42 |
how to analyze the temporal dissipation and dispersion errors? | hadesmajesty | Main CFD Forum | 2 | April 22, 2009 23:15 |
Numerical diffusion/dispersion/dissipation | Hadian | Main CFD Forum | 1 | March 29, 2005 19:33 |
