"Shear layer" vs. "mixing layer"- Difference
Like Tree26Likes
  • 7 Post By Tom
  • 19 Post By afroz_javed
Old   April 17, 2008, 14:59
Default "Shear layer" vs. "mixing layer"- Difference
mazadeh
Does anyone know what is the difference between a Shear Layer and a Mixing Layer?
Thanks, MAZ
Old   April 18, 2008, 05:35
Default Re: "Shear layer" vs. "mixing layer"- Difference
Tom
They're the same thing in general ( a mixing layer is also a shear layer) - although you could argue that the converse is not true; i.e. not all shear layers are mixing layers. This is however just semantics.
Old   April 18, 2008, 09:01
mazadeh
Thanks for your reply. Why the converse is not true?
Actually I have seen in couple of strong fluid dynamic papers that they distinguish between mixing layer and shear layer for example they say: "this flow behaves more like a shear layer than a mixing layer" but they do not explain the difference. I though may be to be more specific a mixing layer is created of the interaction of two different fluids that both have a non-zero velocity and probably different densities, while the shear layer is created when one is quasi-still like a the interaction of a flow past the quasi-still flow inside an open cavity. But in general I believe that both are pretty much the same.
Old   April 18, 2008, 10:11
Tom
In general a mixing layer is what is commonly called a "free shear layer". The mixing aspect arises because of the Kelvin-Helmholtz instability which causes it to wrap up into the so-called cats-eyes structures.
The reason the converse is not generally the case is that boundary layers (especially with separation) are layers with strong shear and can be called (and in the case with separation are) shear layers; i.e. there are significant boundary effects which are not present in the free shear layer case.
Fresh, 8cold8hot, Asura and 4 others like this.
Old   April 18, 2008, 15:40
mazadeh
Got it. Thanks Tom!
Old   April 10, 2009, 11:17
Default Mixing Layer and shear layer
afroz_javed is on a distinguished road
when two parallel streams of fluids meet at an interface with a velocity difference a shear layer is formed. By defination a shear layer is a layer of flow where a shear or velocity gradient exists. Going by this, boundary layer is also a form of shear layer. But in boundary layer the momentum transport is affected by a solid interface and viscous forces are dominant upto some distance. In case of a shear layer forming at a parallel fluid flow interface the viscous forces are not dominant and the flow is dominated by turbulent transport of momentum. This layer is sometimes called mixing layer also. But some authors call this fluid interface shear layer as mixing layer when the mixing of two species is involved, e.g., mixing of two parallel streams of two different gases at different velocities.
tiam, Fresh, aerosjc and 16 others like this.
afroz_javed is offline   Reply With Quote
Old   September 17, 2019, 04:26
Lightbulb Free shear flows explained
Tomer
Avr.Tomer is on a distinguished road
I have what I find as quite a good heuristic explanation about the different free shear flow in:
https://cfdisraelblog.wordpress.com/...w-of-the-wall/
Avr.Tomer is offline   Reply With Quote
difference free Shear layer and boundary layer noridk_14 Main CFD Forum 0 June 15, 2011 15:15
"Shear layer" vs. "mixing layer"- Difference mazadeh FLUENT 2 April 18, 2008 15:46
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
Validation of shear mixing layer using kwsst Samuell FLUENT 0 September 9, 2003 23:46
Validation of shear mixing layer using kwsst Samuell FLUENT 0 September 9, 2003 23:27
