December 13, 2014, 23:33 |
Approximating 3D models to 2D models
Sindh
can someone guide me that when can we simulate 3D geometries into 2D geometries. I have a project for college and i want to know that whether i can model it in 2d
i have attached the geometry,i need to heat the middle section as it is a resistojet |
December 14, 2014, 10:18 |
Tom-Robin Teschner
Rep Power: 16 |
what are you interested in? (mean) velocity profiles? pressure drop? ... is it a RANS or LES (DNS?) simulation?
is the wall only heated from the top and bottom or also from the sidewalls? from the geometry it looks as if you have a some kind of a diffuser in the third direction therefore it is a bit tricky / risky to approximate it with a 2d model |
December 14, 2014, 23:01 |
Sindh
I need pressure drop and velocity profiles at nozzle exit,the walls are heated from the sides only,can u please guide me in general when can we approximate a given geometry to 2d models
December 15, 2014, 05:54 |
Tom-Robin Teschner
Rep Power: 16 |
in that case i don't think you can approximate it with a 2d model.
i would say in general you can approximate two dimensionality when you can make your mesh two dimensional and then extrude it in the 3rd direction in order to get a 3d mesh. now for that you would also need at least symmetry or probably even better, periodic boundary conditions (always depending on the flow you have). in your case you said that the side walls need to be heated so you can't reduce this direction to obtain a 2d grid and you can't reduce it in any other direction as you have geometrical features in all three coordinate directions. another point (general speaking), you can't actually approximate a flow by a 2d model / mesh. for high reynolds number flows you encounter turbulences that are inherently 3d, when approximating it by a 2d mesh, the vortex stretching term will disappear and you no longer have a cascade of large energy eddies to smaller ones. thankfully that is not a primary concern for engineers as we are most interested in "mean" flow profiles and hence using the RANS equations allows 2d meshes as they are just modelling the reynolds stresses but not calculating them exactly. so again, in your case you should proceed with a 3d model, i can't see any easier 2d way. cheers |
cfd |
Mesh requirements for k-w models | Jeremie84 | FLUENT | 5 | June 13, 2014 10:49 |
Eddy Viscosity Models and Reynolds Stress Models | JuPa | CFX | 1 | August 20, 2013 19:56 |
Eddy viscosity hypothesis versus Reynolds stress models | JuPa | ANSYS | 0 | August 12, 2013 07:20 |
Incompressible Turbulence models | achinta | OpenFOAM | 4 | May 27, 2010 11:35 |
Two-fluid models vs mixture models for bubbly flows | Hansong Tang | Main CFD Forum | 6 | December 8, 2009 04:21 |
