Rep Power: 12 ![]() |
I need a finite volume incompressible fluid flow 2d solver code in FORTRAN (based on simple or simpler algorithm). Where I can find ? My code is not converging and giving problem in pressure correction equation from discretized continuity equation. I am using SIMPLE algorithm.
Md. Intishar Rahman
Rep Power: 11 ![]() |
Hello Dansys,
I am also facing the same problem. I used velocity under relaxation factor as 0.25 and pressure relaxation factor as 0.1 But my solution doesn't converge unless I take the zero pressure corrections at the boundaries equal to the pressure correction of the next node towards the domain. |
#3 | |
Troy Snyder
Rep Power: 19 ![]() |
There are a multitude of codes which implement SIMPLE and SIMPLEC in both 2d and 3d. They are written in FORTRAN. Here is a link to the ftp site: ftp://ftp.springer.de/pub/technik/peric/ |
Md. Intishar Rahman
Mr. tas38,
Thank you very much, I am having problem in accessing the site. Can you kindly send the codes to my mail intishar.rahman@gmail.com? I would be very greatful. |
fortran code, navier stokes equations, simple algorithm |
How to call FORTRAN files as UDF? | Ehsan-F | Fluent UDF and Scheme Programming | 6 | September 11, 2012 11:03 |
CGNS fortran code compiling with intel visual fortran xe | dokeun | Main CFD Forum | 1 | April 5, 2012 21:01 |
Discontinuous Galerkin schemes -- fortran source code | diedro | Main CFD Forum | 3 | March 12, 2011 10:20 |
Who can find me this fortran code 'CHEMR'? | Dong Ye | Main CFD Forum | 1 | October 13, 2005 17:02 |
Design Integration with CFD? | John C. Chien | Main CFD Forum | 19 | May 17, 2001 15:56 |
