September 10, 2007, 13:35 |
Slope limiter vs. Flux limiter
Is there anyone acknowledging that which one is superior? Many CFD references mentioned both of them but no one explains about the fact that which one is better. Please give me your knowledge about this issue.
September 11, 2007, 04:38 |
Re: Slope limiter vs. Flux limiter
Hi Jinwon
I didn't there was a difference between the two. Most of what I know about limiters comes from a book by Hirsch:Numerical computation of internal and external flows. Cheers Shuo |
September 11, 2007, 09:17 |
The reason of my question is the structure of the solution method. The slope limiter in the Euler euqation needs to deal with it in the local characteristic variables based on the eigen-system while the flux limiter does not seem like. Anyway, thanks for your reply.
Jinwon |
September 11, 2007, 10:55 |
Flux limiters are typically applied directly to the fluxes, rather than the flow or characteristic variables. Hirsch touches on this in vol. 2 of his books. In using flux limiters, one usually extrapolates the fluxes to the cell face (via MUSCL, QUICK, etc.) and then limits the flux extrapolation. The formulas for limiting and extrapolation are the same between the two approaches, but variable extrapolation and slope-limiting seems to make better use of the built-in dissipation arising from the specific non-linearities of the flow equations (ref. Hirsch, Numerical Computation of Internal and External Flows, V. 2, pp. 508-509).
Ultimate Flux Limiter | gentela | Main CFD Forum | 1 | August 2, 2016 20:55 |
slope limiter and flux limiter ?? | Ameya J | Main CFD Forum | 1 | June 13, 2011 12:05 |
flux limiter involving tensor : How to use fvc::flux() with volTensorField ? | Cyp | OpenFOAM Programming & Development | 2 | January 21, 2011 04:36 |
Lax-Wendroff flux, using any flux limiter | mcaro | Main CFD Forum | 1 | September 30, 2010 11:37 |
Flux Limiter | Q. Liu | Main CFD Forum | 4 | August 6, 1999 22:36 |
