simple divergence
Like Tree2Likes
  • 1 Post By sciense
  • 1 Post By gafoorcp
Old   August 18, 2014, 09:12
Default simple divergence
ali
sciense is on a distinguished road
i have divergence at high Re number in my simple code and it gives negative pressure and unusual osilation
but as i know simple doesnt need turbulent model to converge at high Re !!
how can i over come to this problem
thanks
gafoorcp likes this.
sciense is offline   Reply With Quote
Old   August 18, 2014, 17:17
ABDUL GAFOOR CP
gafoorcp is on a distinguished road
hii....
can you elaborate the details of the problem...
and also one reason for divergence of solution will comes from mesh generation...
regards
Vino likes this.
gafoorcp is offline   Reply With Quote
Old   August 19, 2014, 16:14
Vino
Vino is on a distinguished road
Did you check your solution for low Re? Plz give the details of the simulation you are doing. You can try the simulation with lower cfl no than what you are using already.
Vino is offline   Reply With Quote
Old   August 24, 2014, 14:31
ali
Originally Posted by Vino View Post
im using patankar's simple method with hybrid scheme and my cfl no is letter than 1
in low Re the converging is very well but in high Re it has a very large divergences and negative results for pressure and velocity
finite volume method, simple
Continuity divergence in simple gas flow Okka FLUENT 7 January 11, 2019 02:01
Divergence Error in my Simulation utsavac FLUENT 0 July 2, 2014 04:15
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 18:02
Help with coding SIMPLE for Lid-Driven Cavity samgregson Main CFD Forum 6 September 12, 2013 23:48
Timestep and Pressure Correction Relationship in SIMPLE rks171 Main CFD Forum 23 May 4, 2012 02:04
