Dirichlet conditions for pressure
Like Tree3Likes
  • 1 Post By harry123
  • 2 Post By skchoi
Old   August 6, 2014, 10:20
Default Dirichlet conditions for pressure
harry123 is on a distinguished road
I wish to know under what requirements, a dirichlet boundary condition for pressure is implemented. I have mostly found literature dealing with neumann bc for pressure.
It would be of great help if anyone could point out some good read for getting an understanding on need and implementation of dirichlet bc for pressure.
I work with a FVM and SIMPLE algorithm.
Thank you,
Harry
harry123 is offline   Reply With Quote
Old   August 6, 2014, 11:54
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by harry123 View Post
Thank you,
Harry
Speaking about the elliptic pressure equation, for example, you can have a tank filled of fluid and a flow coming through outflow in some pressure-fixed environment.
FMDenaro is offline   Reply With Quote
Old   August 6, 2014, 12:22
Thanks for that...
Can you please suggest some literature that may help me in understanding how to actually implement this in the pressure poisson equation..?
Old   August 6, 2014, 12:29
Thanks for that...
http://onlinelibrary.wiley.com/doi/1...80905/abstract
Old   August 6, 2014, 16:53
Thank you very much..!!!
FMDenaro likes this.
Old   August 7, 2014, 18:24
leflix is on a distinguished road
Harry
Pay attention that with SIMPLE you solve a kind of Poisson equation for the pressure correction not for the pressure itself.
The boundary conditions for this pressure correction equation is generally Neumann boundary condition on all boundaries.
leflix is offline   Reply With Quote
Old   August 8, 2014, 04:01
Yes...and thats what confuses me...
If I wanted to explicitly specify the pressure value at a boundary (say 10 Pa), how do I incorporate that into the SIMPLE algorithm ?
Do I use the neumann condition for boundaries in pressure correction equation as usual and do something extra for this particular boundary ? Because, having an explicit pressure value means pressure correction is zero at that particular node ?
Old   August 16, 2014, 15:44
Yes Harry in this case I agree with you...I should do exactly as you suggest it. Zero for the pressure correction, which means Dirichlet boundary condition for the pressure correction with a zero value.
Generally on open boundary we rather prescribe velocity boundary condition rather than pressure, in this case Neumann BC for pressure correction is correct.
Old   August 21, 2014, 00:47
Seok-Ki Choi
skchoi is on a distinguished road
Please read the following papers;
(1) S. R. Mathur and J. Y. Murthy, "Pressure Boundary Conditions for Incompressible Flow Using Unstructured Meshes" Numerical Heat Transfer, Part B, Vol. 32, pp. 283-298, 1997.
(2) K. M. Kelkar and D. Choudhury, "Numerical Method for The Prediction of Incompressible Flow and Heat Transfer in Domains with Specified Pressure Boundary Conditions", Numerical Heat Transfer, Part B, Vol. 38, pp. 15-36, 2000.
harry123 and fakhr010 like this.
skchoi is offline   Reply With Quote
dirichlet pressure
Export boundary setting in Fluent 14.0 asal FLUENT 4 September 28, 2017 10:40
non reflective boundary conditions for incompresible flow Pascal_doran OpenFOAM Programming & Development 16 August 25, 2015 06:35
Update boundary conditions calculated by an external program CedricVH OpenFOAM 2 January 15, 2010 12:55
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Boundary conditions? Tom Main CFD Forum 0 November 5, 2002 02:54
