2d Windshield De-Icing Mesh Model
Like Tree1Likes
  • 1 Post By lovecraft22
Old   July 25, 2014, 08:25
Default 2d Windshield De-Icing Mesh Model
Serhan TATAR
serhan is on a distinguished road
Hello guys,
I am simulation 2D windshield de-icing problem but I have some problems. As you see from the snapshots velocity BL is not smooth. I tryed different mesh models but counter does not changed. Should I at inflation on inlet side also(I added only for windshield)? When I do that, reduced cells are produced..I am new at fluid analysis and Ansys, so your help will be appreciated
Could anyone advise a solution?
serhan is offline   Reply With Quote
Old   July 26, 2014, 14:35
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
You don't have enough resolution in the lower pipe. Do you really need to simulate the flow inside that region? Otherwise you could just put your inlet at the top of it…
serhan likes this.
lovecraft22 is offline   Reply With Quote
Old   July 27, 2014, 07:42
Serhan TATAR
I refined the mesh and results are now better converged. Air inlet must be inclined relative to the front surface so I need this pipe. What do you think about the residuals? It is converged but continuity fluctuates a little bit, is it normal? I solved the problem at steady state with RNG k-eps turbulans model....
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh eddyy19g ANSYS Meshing & Geometry 3 February 13, 2014 10:36
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
