Extract velocity fluctuations from flow pasta a circular cylinder
Like Tree3Likes
  • 1 Post By flotus1
  • 1 Post By FMDenaro
  • 1 Post By lovecraft22
Old   July 23, 2014, 08:22
Default Extract velocity fluctuations from flow pasta a circular cylinder
FP
FPereira is on a distinguished road
I'm simulating the flow past a circular cylinder with LES, and in order to check its quality I'm writing the "instantaneous" velocity field at certain nodes (for each time step). To obtain the velocity fluctuations at these nodes I have to subtract the mean-flow velocity. However, due to the vortex shedding, the mean-flow is not constant. Can anyone tell me or give me some tips/references about the way to solve this issue. Is removing the mean-flow frequency with an fft a good/accurate approach?
Maybe the answer to this question is obvious but I'm new using LES.
Thank in advance
F.Pereira
FPereira is offline   Reply With Quote
Old   July 23, 2014, 08:30
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
However, due to the vortex shedding, the mean velocity is not constant
Think about this statement again. The mean velocity is constant by definition.
But if you really need to separate the slow fluctuations from the fast ones for whatever reason, a high pass filtering operation could be applied.
However, I dont think that this is what you really want.
FMDenaro likes this.
flotus1 is offline   Reply With Quote
Old   July 24, 2014, 04:52
FP
Yes, the statement was not correct. I was referring to the mean-flow velocity.
About your last statement.
One of my goals is to obtain the energy cascade. Then, shouldn't I consider only velocity fluctuations?
Thanks
Old   July 24, 2014, 04:57
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
the key is that in LES you solve for v_bar(x,t), then you have to compute:
v_mean(x) = (1/T) Int [t0, t0+T] v_bar(x,t) dt
for T sufficiently large that is statistically meaningful.
Practically, I suggest to sample the velocity field, for examples storing the data and then post-processing the average. You need to store enough sample
DaveyBaby likes this.
FMDenaro is offline   Reply With Quote
Old   July 25, 2014, 06:02
DaveyBaby
DaveyBaby is on a distinguished road
Hi!
Following on from Denaro's comment, in order to be confident that you have made T sufficiently large and also to gain useful info about the periodic phenomena you need to first know the period of the oscillations. You can make a rough estimate of this by looking at the Strouhal number you would expect for your case (find in a journal paper) and working backwards.
DaveyBaby is offline   Reply With Quote
Old   July 26, 2014, 14:23
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
You don't need to subtract the mean field, the FFT (or whatever signal analysis you'll perform) will take care of that. Just record your velocity and feed the signal processing with that.
As already mentioned, you need to make sure your signal is recorded at a frequency that complies with the Nyquist rule and it also must be long enough for the signal analysis to return the lowest frequency you are expecting. This is however out of the original question.
lovecraft22 is offline   Reply With Quote
Old   July 26, 2014, 14:40
FP
Thank you all for your answers. lovecraft22, I understand that for the energy cascade it might not be necessary to remove the mean field but if, for instance, your are trying to compare turbulent kinetic energy profiles with experimental data you should need to remove it, right?. I tried to remove the mean field using high-pass filters or by fft (removing the mean-flow frequencies). My point is: how accurate is this? Are there better methods to do it?
Thanks
flow around a cylinder, instantaneous velocity
2D flow around a circular cylinder case with interFoam solver shuoxue OpenFOAM Running, Solving & CFD 0 August 31, 2013 06:04
DSMC results of low-Mach flow over circular cylinder flotus1 Main CFD Forum 2 November 13, 2012 11:37
Incorrect Drag and Drag Coefficient for flow over a cylinder ozzythewise Main CFD Forum 8 June 13, 2012 07:24
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 11:05
Turbulent steady flow around a circular cylinder Mirek Kabacinski FLUENT 0 July 23, 2003 19:40
