July 5, 2014, 08:23 |
Use of laminar model for a turbulent flow
Josef Camilleri
Rep Power: 12 |
Hi all,
I am modelling a wedge free falling from a height of 0.5 into a calm water surface and measuring the pressures acting on the wedge bottom. I am using a laminar model even though the Reynolds number (3e6) suggests that the flow is turbulent. The reason for this is that the water entry of a wedge is characterised by high slamming pressures. My question is, what does using a laminar model for a turbulent flow mean? Is it just ignoring the turbulent shear stresses? Also, when using a laminar model for a turbulent flow, does the mesh in the vicinity of the bottom surface (prism layers) have to satisfy the requirements of turbulence models? That is, does the thickness of the 1st prism layer still have to be such that good Y+ values are obtained? Thanks for your help. Josef |
July 6, 2014, 07:54 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
"laminar" is not exactly a model, actually it is an expression to say "I use Navier-Stokes equation without any filtering/statistical averaging and (turbulence) modelling". This does not imply that your "laminar model" cannot solve turbulence, if you have enough computational power and a grid resolution resolving the smallest turbulent structures, you will simulate turbulence within the Direct Numerical Simulation (DNS) formulation. |
Ratio of eddy viscosity to molecular viscosity : Laminar or turbulent flow? | JuPa | CFX | 7 | September 9, 2013 08:45 |
turbulent or laminar flow | student2008 | Main CFD Forum | 5 | August 24, 2013 06:33 |
Is this understanding of turbulence models correct? | 3kha | Main CFD Forum | 3 | January 31, 2011 22:31 |
Turbulence model for Laminar flow | Terry | Main CFD Forum | 8 | August 14, 2010 06:45 |
2D cylinder, external, laminar and turbulent flow | Dave | FLUENT | 0 | December 6, 2006 21:42 |
