Mixing two immiscible liquids in Kenics static mixers |
June 27, 2014, 02:03 |
Long Nguyen
Rep Power: 13 |
Dear all,
I am conducting the 3D model of mixing two immiscible liquids in Kenics static mixer. Two flows of palm oil (100% oil) and methanol solution (100% methanol) will be injected at the inlet zone with the specific velocities. I would like to evaluate the fraction of methanol at the outlet boundary (desired volume fraction of methanol is about 0.5). I'm wondring some issues as follow: - Which multiphase model should I apply for this case? (VOF or mixture or Euler) - I have set the outlet boundary as pressure outlet of 0 Pa (gauge) and the blacflow volume fraction of methanol (2nd phase) = 0.5. Is it ok? - What kind of parameter should I use to evaluate how well mixing? (I'm using the volume fraction of each phase as the eveluated parameters) Thanks in advance! (Sorry about my English) Regards, Long Nguyen |
May 26, 2017, 04:27 |
bosi
Rep Power: 10 |
I am facing the same problem can anyone help me |
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 05:24 |
fprint problem | MASOUD | Fluent UDF and Scheme Programming | 5 | October 30, 2011 17:08 |
defining a term for a domain using DEFINE_ADJUST | MASOUD | Fluent UDF and Scheme Programming | 1 | September 24, 2010 06:08 |
Read inside a class | tonyuprm | OpenFOAM | 12 | July 14, 2010 03:35 |
enum | MASOUD | Fluent UDF and Scheme Programming | 0 | June 5, 2010 01:49 |
