Dissipation calculation in LES - Isotropic turbulence |
March 24, 2014, 13:40 |
Rep Power: 16 |
Hi everyone;
I am trying to calculate de dissipation of an LES simulation, but I am not getting the correct value. I am doing a decaying isotropic turbulence, then the derivative of the energy with respect to time should be equal to my -dissipation: dE/dt=-epsilon. If I calculate dE/dt in my simulations, my results are in agreement with a DNS simulation (A. Wray in the AGARD database), so the flow behaviour is correct. However if I calculate epsilon directly from the filtered velocity field it does not give me the correct value. I do not think is a coding error, probably my formulation of epsilon is not correct. I am calculating my total dissipation (modelled + resolved) as: epsilon=2*(nu+nuSgs)*(S::S) where S is the strain-rate Is this valid for decaying isotropic turbulence? Any suggestions or ideas of what I might be doing wrong ? Am I missing something? Thanks for your help and have a nice day, Mary |
March 24, 2014, 13:49 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
of course the expression for dissipation does not depend on the type of flow, it must be general... Said that, if you assume no production of energy, the balance dE/dt=-epsilon must be true even at the initial condition but that does not hold from your figure. |
March 25, 2014, 14:18 |
Rep Power: 16 |
Thanks Filippo, what I ment to say is if my expression for the dissipation is correct?
epsilon=2*(nu+nuSgs)*(S::S) or what could it be the reason for this discrepancy in my results? |
March 25, 2014, 16:33 |
Rep Power: 73 |
the expression of the total dissipation you wrote is correct, of course coding it can have some errors...
Anyway, check a t=0 both dE/dt and the dissipation ... |
dissipation, isotropic turbulence, les |
LES calculation of EPSILON (turbulence dissipation) | Gosi | OpenFOAM Post-Processing | 4 | July 9, 2016 05:58 |
Default inlet turbulence for LES | N Barton | CFX | 11 | July 24, 2015 01:34 |
Calculation of initial k for RAS turbulence models | shipman | OpenFOAM | 1 | August 28, 2013 04:52 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
calculation of (turbulent) dissipation energy ? | max | Main CFD Forum | 3 | August 18, 1999 10:42 |
