SA turbulence model implementation issue
Like Tree2Likes
  • 1 Post By SergeAS
  • 1 Post By som87
Old   February 6, 2014, 06:31
Default SA turbulence model implementation issue
shikhar
jaiswal is on a distinguished road
i am trying to implement spalart almaras turbulence model in 2D Navier-Stokes solver.
Even after spending lot of time im not successful.
My first doubt is whether im using d (distance from the closest surface) correctly or not.
How is d calculated?
I am doing calculation on NACA 0012 airfoil. And to find the distance from closest surface for a grid point, im calculating distance from the grid point to all the points on the body (in this case NACA 0012 airfoil) and using the minimum of the distance among them.
Is this the correct way to find distance from the closest surface?
jaiswal is offline   Reply With Quote
Old   February 6, 2014, 13:07
som87 is on a distinguished road
The way you are calculating the wall distance is highly dependent to your mesh.
If your have unstructured (say triangular) mesh, then it'll not give you correct answer.
If that is the case, I suggest to maintain the index and try to use the index (say j=1 to j=2) to get the grid distance
Best wishes,
Somdeb Bandopadhyay
som87 is offline   Reply With Quote
Old   February 6, 2014, 23:59
shikhar
Hi Somdeb!... thank you for ur reply
I am not very clear what you are telling Somdeb. I am using structured mesh. I am using C-grid of 257*60 size. I have 197 points on the airfoil. Suppose i want to find closest distance from surface for a grid point say i = 30 & j = 20 then i find distance for this grid point from all the points on the airfoil i.e. j = 1 & i = 31 to 227 ( 197 points) and take minimum of the distance among them.
Is this the right way to find distance from the closest surface, for use in turbulence model calculations? Or is there a better way to do it?
Old   February 7, 2014, 14:41
SergeAS's Avatar
Serge A. Suchkov
SergeAS is on a distinguished road
Send a message via Skype™ to SergeAS
Your algorithm is correct, but you keep in mind that for huge meshes and complicated wall shape this algorithm quite slow. For above specified mesh it will be insignificant, but if you want to propagate it to a larger 3D mesh, you will see this. Moreover, if you need to deform the mesh, this procedure will be repeated after each mesh modification. I use a similar algorithm in my 3D code but I have special parallel version for this case.
As example on 600k nodes mesh for ~1200 wall nodes this procedure takes 15 sec on 4-core CPU and less 5 sec on GPU
jaiswal likes this.
OpenHyperFLOW2D Project
SergeAS is offline   Reply With Quote
Old   February 7, 2014, 21:27
Hi again, sorry for late reply.
Yes, your algorithm is correct.
About my previous comment, I didnt know about your grid's details
While we are in topic, SA turb model is a static type model right? So it will not give good result most cases
Cheers
jaiswal likes this.
Best wishes,
Somdeb Bandopadhyay
Old   February 10, 2014, 00:30
shikhar
Thank you Serge ... Now it is very clear to me... your information was very helpful... since i am calculating d correctly there is some other implementation issue... I will try to sort out...
Old   February 10, 2014, 00:37
shikhar
Hi Somdeb!... thank u once again for replying...
Now it is clear to me that my algorithm to find distance is correct.
what do u mean by static type model?... I am still not successful in my implementation, so maybe it is important to me... can u pls explain?
Old   February 10, 2014, 01:15
Hi again, I just commented on the fact that we marely calculate the eddy viscosity in SA model and there is no further coupling between the original NS PDE (like it is in k omega or k epsilon).
I am sure it will not affect your work in implementing SA model in your code. I didnt want to cause any misunderstanding
Best wishes,
Somdeb Bandopadhyay
Old   February 10, 2014, 23:42
shikhar
K... Thank you Somdeb
Implementation of turbulence model idefix OpenFOAM Programming & Development 1 March 28, 2013 06:43
Implementation of turbulence model idefix OpenFOAM Programming & Development 5 March 27, 2013 02:22
issue compiling new turbulence model perplexed user OpenFOAM Programming & Development 1 January 13, 2012 04:40
Fan heater model: what turbulence source to use? andy20 Main CFD Forum 0 March 2, 2008 13:46
A reference on implementation of Spalart-Alam. Turbulence Model? Mohammad Kermani Main CFD Forum 2 December 26, 1999 03:56
