Detached-eddy simulation
Like Tree1Likes
  • 1 Post By cfdnewbie
Old   January 31, 2014, 10:26
Default Detached-eddy simulation
madcyclop2 is on a distinguished road
Have anyone try to do simulation around square cylinder using DES? Or will the result be the same with LES?
Lastly, can fluent run DES simulation?
Thank you.
madcyclop2 is offline   Reply With Quote
Old   January 31, 2014, 20:03
som87 is on a distinguished road
Hi, let me point out that the implementation of DES in Fluent software is an extended k-omega SST (If I am correct, ANSYS 14.0 has similar situation), the main difference being the procedure in which the numerical solver calculates the dissipation term of the turbulent kinetic energy. The widely used constant (=unit value) term in k-ω SST model is further modified in DES, where its value depends on turbulent length scale, calibration constant & the maximum grid spacing. As a result your solution is resolved just like LES as you move far from bluff-body.As far I know, in DES we do not use a subgrid mode like we do in LES.
Now, to cut the chase short, yes fluent can use DES simulation
Best wishes,
Somdeb Bandopadhyay
som87 is offline   Reply With Quote
Old   February 1, 2014, 10:29
cfdnewbie
cfdnewbie is on a distinguished road
It is difficult to answer that question in a general way. Neither the term LES nor the term DES really defines what exactly happens, or what you are doing in terms of numerics and/or models. It is like saying "I own a car", but that just gives the general idea of 4 wheels and a combustion engine, but can range from a 1920s Ford to a Lamborghini.
So, in very broad terms: No, I wouldn't expect the DES and the LES approach to give the same result (one would have to define what you mean by the "same" ), as different LES approaches will already give you completely different results.
You will certainly get a result with both DES and LES, but how to interpret the validity of it will be tricky.
FMDenaro likes this.
cfdnewbie is offline   Reply With Quote
des, fluent, les
domain size for Detached Eddy Simulation T FLUENT 0 November 6, 2007 13:23
Detached Eddy Simulation in industry Fab Main CFD Forum 3 January 18, 2007 15:50
Large eddy simulation David FLUENT 1 December 11, 2006 13:18
Detached Eddy Simulation Juan Guevara CFX 3 December 21, 2005 15:47
Large Eddy simulation Andreas Hauser Main CFD Forum 1 May 20, 2000 21:33
