The role of CFD in vehicle aerodynamics design and the reasons |
January 31, 2014, 06:24 |
Meimei Wang
Rep Power: 16 |
I currently read articles telling that CFD still has very bad accuracy for vehicle aerodynamics design. So the vehicle aerodynamics design is still driven by experience & experiment. In the near future (next 10 years), the accuracy of CFD on that won't be improved a lot. I'm wondering what are the origins of the inaccuracy? Is that because vehicle always has bluff rear part so that the BL separation can not be avoided. And if there's BL separation at the rear part, the pressure distribution at the rear part can't be predicted nicely so the drag prediction will be very bad? I'm also wondering what is the role of CFD in vehicle aerodynamics design in the car industry nowadays? What do you think about what its role will be in the near future?
Best regards, Meimei |
February 3, 2014, 12:15 |
#2 | |
Meimei Wang
Rep Power: 16 |
February 3, 2014, 13:00 |
Rep Power: 14 |
1.The "funding" needed for a "highly accurate" cfd analysis will raise the production cost resulting in raise in the sell off prize of the product. Consider a space vehicle or defence-aircraft project..in that case the aim is not commertial success, hence more effort>high accuracy whereas for our normal industry the "economic" (not computational) aspect will always be a burden for good quality research.
2. On future of CFD's application on vehicle aerodynamic design, from my view there'll be little effort on "improving" the accuracy. Instead topics like Automatic Differentiation (eg tapenade) will have more funding.
Best wishes, Somdeb Bandopadhyay |
February 3, 2014, 13:13 |
#4 | |
Meimei Wang
Rep Power: 16 |
February 3, 2014, 13:23 |
#5 | |
Rep Power: 14 |
On other note, turbomachinary has a much wider place and there are still enough openings to do quality research.So, the accuracy level of cfd analysis in turbomachinary is often high enough to ensure a quality work. (signing off for now)
February 3, 2014, 14:45 |
#6 | |
Meimei Wang
Rep Power: 16 |
February 3, 2014, 18:16 |
Jon
Rep Power: 13 |
CFD is already being extensively used in industry and the accuracy can easily match that of the wind tunnel.
The hardest thing is getting the geometry and testing conditions correct. Even modelling things such as tyre squash can have an influence on the prediction. Race cars quite often go straight from CFD to the track with good correlation. |
February 3, 2014, 18:22 |
#8 | |
Rep Power: 14 |
The need of accuracy dominates the quality of work. For top notch racing cars (after all, they are our batmobile) the accuracy criterea should be of highest standard. But apart from that, if we focus on the mre generalized part of vehicle industry, its more CAE than CFD.
February 3, 2014, 18:52 |
#9 |
Tom-Robin Teschner
Rep Power: 17 |
I am actually surprised to hear that. My experience is more that, especially in the last ten years, CFD has become a major role in many areas and even in vehicle aerodynamics. i agree that bluff body aerodynamics is quite challaging, especially if you are interested in drag prediction. although if you look at drag and friction prediction on say, the ahmed body, current RANS model can predict the value of the drag coefficient quite well and also reconstruct the flow field in the wake to a satisfactory degree. (well ok, satisfactory degree is probably a matter of definition but you get as close as 5% if I remember from my simulations.
I was talking about exactly that (accuracy of CFD simulation) with the head of CFD from jaguar landrover, UK, and he told me that CFD is widely used in his company and that they use a lattice boltzman based approach because it presumably gives you better results in terms of accuracy then a navier stokes based solver. and that is not only him, the rest of the industry is using the LBM for their simulation. furthermore, you have to consider that computational resources are becoming more and more available so we are currently at the edge where industry is starting to use large eddy simulations. this supposedly should also increase your accuracy. one last point is, although it sounds obvious, but it all comes down to who is doing the simulation. from meshing to solver settings to post processing, there is a lot that can be done wrong. |
February 3, 2014, 18:55 |
#10 |
Tom-Robin Teschner
Rep Power: 17 |
That's what I've thought as well ... but after having to learn how CFD is incorporated into formula 1, I was quite surprised to see how big the tolerances were (however, as long as they are able to corelate their data to track and wind tunnel test, it seems to give them still good results, if however more in an engineering sense
February 3, 2014, 18:58 |
#11 |
Rep Power: 14 |
I am sooo tempted to start an arguement XD (jk)
February 4, 2014, 05:56 |
#12 | |
Meimei Wang
Rep Power: 16 |
