January 24, 2014, 22:25 |
Spatial accuracy vs. Temporal accuracy
yehanyu
Rep Power: 14 |
In many CFD codes, spatial discretization scheme is often less accurate than temporal discretization scheme. For example, one might adopt a second-order spatial scheme and use the fourth-order Runge-Kutta method to perform temporal integration. I just don’t understand the reason behind this scenario. Since the spatial scheme is second-order accurate, it seems that a fourth-order accurate temporal scheme doesn’t help to improve the overall accuracy of the solution. Is my point of view correct? Thank you very much.
January 25, 2014, 04:35 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
In principle, you are correct. However, high order time integration is expecially suited for simulation of turbulence, with LES/DNS. This is due to the fact that one wants to exclude effects of filtering/truncation errors over the temporal scales and focus only on spatial scale. Furthermore, it is quite obvious that for stability reason O(dt) = (1/U) O(h) |
February 20, 2014, 03:42 |
yehanyu
Rep Power: 14 |
February 20, 2014, 06:06 |
#4 | |
duri
Rep Power: 17 |
February 20, 2014, 07:42 |
#5 | |
Rep Power: 73 |
well, I am not sure what you want to say with "The purpose of RK is to damp high frequency errors" ... When the dt is fixed, you implicitly cut-off all the frequencies over pi/dt. The frequencies below have to be resolved at best without damping... |
accuracy, spatial, temporal |
Best approach to study temporal and spatial convergence | ndabir | Main CFD Forum | 6 | July 16, 2013 10:46 |
Temporal and Spatial averages | shahzad_munir | Main CFD Forum | 0 | September 18, 2012 06:09 |
Temporal accuracy | ganesh | Main CFD Forum | 0 | February 29, 2008 05:32 |
FIDAP spatial accuracy | Ingo Meisel | FLUENT | 0 | March 8, 2004 10:58 |
1st order temporal & 2nd order spatial | Prateep Chatterjee | FLUENT | 0 | January 19, 2003 00:31 |
