Wind Turbine Air Flow Analysis
Like Tree1Likes
  • 1 Post By flotus1
Old   January 22, 2014, 13:26
Lightbulb Wind Turbine Air Flow Analysis
NightHawkRaven is on a distinguished road
Hey,
Does anybody know how to simulate and analyze the airflow pattern around a wind turbine using Ansys or any other simulation software for that matter ? I'm looking for a 3D model !
NightHawkRaven is offline   Reply With Quote
Old   January 22, 2014, 13:47
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
Have a look at tutorial number 14: Using sliding meshes.
Apart from that: http://www.cfd-online.com/Wiki/Ansys...ible_answer.3F
NightHawkRaven likes this.
flotus1 is offline   Reply With Quote
Old   January 22, 2014, 13:57
Lightbulb Wind Turbine Air Flow Anlaysis
Hello Alex,
I'm new to this forum and hence not quite familiar with the rules to be followed. I'll surely try to improve and be as specific as possible with my future posts. In response to your reply, where can I find the tutorial that you mentioned ?
Regards
Night Hawk Raven
Old   January 22, 2014, 15:00
flotus1's Avatar
Alex
It can be found within the fluent documentation (check the help button) or downloaded at the Ansys customer portal.
Typing the words "fluent using sliding meshes" into a search engine like google will also bring up some older pdf documents of this tutorial.
The number may be lower than 14, but the content is the same.
You will even find threads dealing with this type of flow if you use the search function of the forum.
air flow simulation, ansys, cfx, fluent, wind turbine
fluent analysis of wind turbine er_ijaz FLUENT 0 May 1, 2013 05:55
Vertical Axis Wind Turbine atorninc Main CFD Forum 3 March 6, 2013 05:38
Unsteady flow over a savonius wind turbine Robyfood Siemens 9 March 14, 2012 10:41
Tutorial related to flow analysis of Hydro turbine Sanjay Jain FLUENT 0 April 10, 2008 10:09
radial turbine flow analysis ME Siemens 1 August 16, 2007 04:06
