External flow turbulent intensity and turbulent viscosity ratio
Like Tree1Likes
  • 1 Post By a.zareinezhad
Old   January 16, 2014, 14:05
Question External flow turbulent intensity and turbulent viscosity ratio
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
I'm doing CFD for light aircraft. I'm wondering what turbulent intensity and turbulent viscosity ratio shall I use for the external flow boundary conditions? What are the typical values used in this area?
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   January 22, 2014, 14:41
Question
Anna Tian's Avatar
Meimei Wang
Originally Posted by Anna Tian View Post
Could anyone answer me this question?
Best regards,
Meimei
Old   January 26, 2014, 14:10
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
for external aerodynamics of aircrafts usually turbulence intensity is below 1% according to what i have heard and seen. Some one more experienced here could guide you further..
Also for a fully developed flow, the T.I = (0.16) * (Reynolds number)^(-1/8) * (Length scale)
shereez234 is offline   Reply With Quote
Old   January 27, 2014, 12:16
Question
Anna Tian's Avatar
Meimei Wang
Thanks for your answer. And what is the typical turbulent viscosity ratio value?
Btw, what are the typical value of them in the wind tunnel? I heard about that, in wind tunnel, usually we have flow much more turbulent.
Best regards,
Meimei
Old   January 27, 2014, 13:15
truffaldino's Avatar
truffaldino is on a distinguished road
For numeric simulation one usually needs turbulent intensity at inlet: for a sailplane T.I free stream turbulence is of order of .01%. For a wind tunnel is about .1%.
For more info see recent post on the same topic
http://www.cfd-online.com/Forums/mai...intensity.html
truffaldino is offline   Reply With Quote
Old   January 27, 2014, 16:21
Question
Anna Tian's Avatar
Meimei Wang
Thank you for your information. It's very helpful. Btw, what should be the value of the turbulent viscosity ratio?
Best regards,
Meimei
Old   January 27, 2014, 17:37
Eddy viscosity has a simple relationship with turbulent energy and length ( http://www.cfd-online.com/Wiki/Turbu...ary_conditions ), so you need the turbulence length. This depends on your inlet conditions (whether this is a wind tunnel with or without grid, athmospheric turbulence etc). Some useful info can be found here:
http://www.cfd-online.com/Wiki/Turbulence_length_scale
I think instead looking for turbulence lenght in tables etc, it is better to do the following: If you to compare your results with measurement, just choose one measurement poit and vary the length until it fits this point, then, using the same length check if the other points will also fit.
Old   January 28, 2014, 04:55
Question
Anna Tian's Avatar
Meimei Wang
I'm wondering, from your experience, will the wing numerical simulation results be sensitive to the inlet turbulence intensity value?
Best regards,
Meimei
Old   January 28, 2014, 09:56
As you could see from the above posts, it will be something like logarithmic dependence, i.e. it is not very sensitive.
Sometimes it is sensitive (e.g. if one uses laminar flow airfoil in critical regime, where the flow is close to transition almost at every point).
Old   February 1, 2014, 23:14
Default Turbulence intensity
a.zareinezhad is on a distinguished road
following link can help you for measuring Turbulence intensity:
How to estimate turbulence quantities to specify at inlet boundaries?
10. Turbulence modeling
jkampman likes this.
a.zareinezhad is offline   Reply With Quote
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 07:15
hel (turbulent viscosity ratio limited) for supersonic combustion problem omar.2002bh FLUENT 2 September 5, 2012 12:04
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 01:05
[OpenFOAM] Turbulent intensity and viscosity ratio gzink ParaView 1 June 30, 2006 18:10
Problem of Turbulent Viscosity Ratio Limited David Yang FLUENT 3 June 3, 2002 07:13
