December 18, 2013, 15:20 |
Flow separation
Vino
Rep Power: 13 |
For flow over circular cylinder, laminar boundary layer separation angle is given as 80 deg (from stag. point) in some books. In some of the literature flow separation angle is given as 125-130 deg (from stag. point). Now my confusion is 1) Does flow separation and boundary layer separation mean the same? 2)What is the laminar boundary layer sep. angle for cylinder(from stag. point)? |
December 18, 2013, 15:38 |
1) yes
2) 2D case or 3D case? |
December 18, 2013, 22:17 |
Rep Power: 19 |
The separation angle is roughly 120 degrees for turbulent flow.
December 27, 2013, 17:10 |
Vino
Rep Power: 13 |
Hi lovecraft22,
Thank you for your answer. I am doing a 2D simulation of flow over cylinder at Re=40(steady laminar). I am not considering boundary layer and my separation angle is around 125 Deg and I found that literature also gives the same results. But in some text books I found that the laminar separation angle is around 80 Deg for cylinder ( don't know whether 2D or 3D). Can you please clarify? |
December 27, 2013, 18:34 |
Which textbook are you talking about? It looks a little bit odd that at Re=40 you have separation at 80°…
December 28, 2013, 09:38 |
Vino
Rep Power: 13 |
Hi lovecraft22,
Fluid Mechanics, F.M.White, 4th edition. Page no-455 given as laminar separation at 82 deg. My 2D laminar flow over cylinder simulation(Re=40) gives separation angle as 125 deg ( which is matching with literature results). Now my question is , why this difference in separation point? I feel both must be right and I am missing something to understand. Plz clarify.!!! |
December 30, 2013, 13:22 |
I've seen the book. It is odd in my opinion to have such a separation at Re=40 but I might be wrong…
December 30, 2013, 20:13 |
Rep Power: 19 |
At a Reynolds number of 40 the flow state is very different than what White describes in his text. It is laminar, but at Re < 100 the separation forms a closed bubble. For Re > 1000 you get laminar flow with an unsteady wake. From Re = 0 to approximately 100 the separation bubble grows in extent on the downstream side of the cylinder. It sounds to me like you are getting confused because you are comparing two dissimilar situations.
December 31, 2013, 04:27 |
#9 |
Vino
Rep Power: 13 |
Thanks agd.!!!
[CFX] Simulation of Flow Separation in a rectangular diffuser - Convergence Problem | anon_b | CFX | 11 | May 6, 2012 20:16 |
Different flow patterns in CFX and Fluent | avi@lpsc | FLUENT | 4 | April 8, 2012 06:12 |
Weir Flow Separation | buzzbromp | CFX | 0 | July 18, 2009 01:08 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 05:18 |
