October 28, 2013, 07:58 |
The old Hex vs Tet question
Rep Power: 16 |
For non-specific flows: 1. Hex is always better than Tet when it comes to accuracy. 2. No, Tet is as good as Hex if both solutions are mesh independent, although Tet require more cells to accomplish that. Is it possible that the question is also related to cell skewness and that many researchers have just compared apples and oranges? Cheers! |
October 28, 2013, 09:25 |
Alex
Rep Power: 49 |
I just finished putting together some "best practice" guidelines on this and some related topics.
My opinion based on my personal experience with commercial CFD software is: You can achieve good results with tet meshes for most engineering applications if you obey the basic rules of mesh generation (overall mesh quality, volume jump, angles, boundary layer resolution...) But you have to know the drawbacks: Solutions with first order upwind schemes on tetrahedral meshes will always suffer from high numerical diffusion. The computing times with tet meshes will be higher for the same accuracy and the overall convergence behavior is worse than with hex meshes. And when it comes to LES with commercial cfd software, I would always choose hex meshes. |
October 28, 2013, 09:57 |
#3 | ||
Rep Power: 16 |
1. How is the second statement related to the first statement? 2. Do you mean that we need more cells in order to reduce numerical diffusion? 3. Numerical diffusion is affected by mesh refinement so I would guess that it is captured when doing a mesh sensitivity analysis? 4. It seems that you are leaning towards the second type of answer in my original post, right? 5. Assume that the flow is at a 45 degree angle with regards to the Hex mesh, now how will this affect the assessment of severe numerical diffusion for the Tet mesh compared to the Hex mesh? Cheers! |
October 28, 2013, 10:43 |
#4 | ||
Alex
Rep Power: 49 |
Simply refining the mesh reduces the numerical diffusion, but only with a slope of 1. If your main focus is accuracy then you will need unreasonably fine meshes just to get rid of this error source. Quote:
Nevertheless, one of the goals when creating hex meshes is to "streamline" the grid to prevent flows with a 45 degree angle with respect to the cells. |
October 28, 2013, 11:21 |
Rep Power: 16 |
Ok so here are some 2d simulations with a commercial software.
The setup is a square domain with inflow at west and south boundary at a 45 degree angle. A passive scalar is introduced with a value of 1 at the west boundary and a value of 0 at the south boundary. Plots are from south-east corner to north-west corner. Check attachments for results. It is clear that the quads have more numerical diffusion in this case. Convergence took much longer for the triangles case. Residuals in both cases were lowered to 1e-8. |
October 28, 2013, 13:28 |
Alex
Rep Power: 49 |
Rotating the flow direction by 90 degrees, you will get a similar diffusion error on the tet mesh.
October 28, 2013, 14:14 |
Rep Power: 16 |
Yes. So does a tri mesh have three preferred directions (low numerical diffusion) as opposed to two directions for quad elements? If yes, then it seems to me that polyhedral elements would be superior, given that they may have even more preferred directions.
October 31, 2013, 07:21 |
Alex
Rep Power: 49 |
I would not draw the same conclusion.
In your test case with the tet mesh, the numerical diffusion is only zero because the line of separation of the passive scalar has the correct direction AND the correct position. If you could move the line of separation by half a cell size, you would still get diffusion errors. Ergo tet elements have no preferred direction at all. |
October 31, 2013, 07:36 |
#9 | |
Rep Power: 16 |
2. Textbooks talk about numerical diffusion being worse when the flow is oblique to the direction of the grid. Should they also add "the correct position" to this statement? (perhaps I don't understand the concept of "grid direction"). Cheers! |
October 31, 2013, 07:48 |
#10 | |
Filippo Maria Denaro
Rep Power: 73 |
numerical diffusion is related to the local truncation error appearing when the convective terms are discretized in non-symmetric way. Hex and Tet cells affects the way in which the discrete operator can be computed on the computational domain. Hex cells are generally associated to structured grids that generate "line directions", Tet cells generates non-structured grid and you cannot uniquely define a grid direction. I suggest to do some simple 2D exercise of the solution of the linear equation df/dt+udf/dx+vdf/y=0, you can prescribe u and v. Try to solve on both triangular grid and hex grid. Try to use upwind and central discretization |
October 31, 2013, 08:01 |
#11 | |
Rep Power: 16 |
[ICEM] hybrid mesh/Aligning tet with hex mesh | shridharsn | ANSYS Meshing & Geometry | 0 | October 17, 2012 12:29 |
[blockMesh] Blockmesh error - 2D scramjet | ishaninair | OpenFOAM Meshing & Mesh Conversion | 7 | March 18, 2011 01:14 |
HEX or TET - Which One is better choice? | MAB | CFX | 16 | July 25, 2008 03:40 |
combination of hex and tet mesh | Raju | CFX | 1 | July 27, 2006 10:10 |
ANSYS ICEM CFD: Hex and Tet Element Specification | Evan | CFX | 1 | May 24, 2006 18:09 |
