Solution at high reynolds numbers
Like Tree4Likes
  • 2 Post By triple_r
  • 1 Post By FMDenaro
Old   October 18, 2013, 03:54
Default Solution at high reynolds numbers
kamyar is on a distinguished road
Hi
I've written a code for solving the Navier Stokes equation using element based finite volume method on a co-located grid.
My problem is that the code works fine when the Reynolds number isn't too high. but when i increase the Reynolds number the code diverges. I've tried to run the code on different problems ( Cavity and flow between two plates) and on all of them i couldn't get any results at high Reynolds numbers.
Does anybody know what the problem could be? It would be great if someone could help me.
thank you
kamyar is offline   Reply With Quote
Old   October 18, 2013, 13:48
Reza
triple_r is on a distinguished road
Are you using any kind of up-winding? Your numerical method might be unstable when Peclet number is high for the elements. Also, do these problems come up when the flow is turbulent? or is the Reynolds number not high enough for turbulence?
FMDenaro and kamyar like this.
triple_r is offline   Reply With Quote
Old   October 18, 2013, 14:30
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
This behavior is typical for some formulations, for example centred discretization in FD and FV methods or spectral methods without de-aliasing or FE without stabilization.
At first, try refining the grid in such a way to estimate a cell Reynolds number no greater than 2. It is stable?
If you are solving turbulence, then you are encountering problem typical of unresolved DNS with non-stabilized method.
Please, give us more details
kamyar likes this.
FMDenaro is offline   Reply With Quote
Old   October 18, 2013, 15:06
The flow is laminar and I'm using the first and second order upwind scheme.
For the cavity problem I could get results for Reynolds number of 1000 but I'm struggling to get results for Reynolds number of 3200. In the case of wavy channel I couldn't get any results for Reynolds number higher than 75.
How can i improve my upwind scheme?
Old   October 18, 2013, 15:12
what about the cfl number you are using?
Old   October 18, 2013, 15:24
I forgot to say I'm solving the Incompressible steady state flow equations.
Old   October 18, 2013, 15:31
ok, consider also that the 2D lid-driven cavity flow starts to become unsteady after Re=1000. I think you should run an unsteady formulation
kamyar likes this.
Old   October 18, 2013, 15:40
Nic T
No Body Cares is on a distinguished road
What kind of up-winding are you using?
No Body Cares is offline   Reply With Quote
Old   October 18, 2013, 15:59
I've used both first and second order upwind scheme. It has been described in versteeg.
Cell Reynolds number cfd help FLUENT 1 August 22, 2005 11:50
high lift devices at low reynolds Pablo Cornejo FLUENT 0 June 28, 2005 22:35
high and low reynolds numbers - what does it mean Bo Busk Jensen Main CFD Forum 3 September 5, 2002 06:41
[Q] Steady Compressible High Reynolds Problem. Ryu, Sung Min Siemens 2 March 31, 2000 13:46
"The high Reynolds number flow is not difficult to compute, the problem is we simply don't know how. wowakai Main CFD Forum 1 November 11, 1998 11:24
