Problems with MFIX code and Parallel Processing.
Like Tree2Likes
  • 1 Post By agg
  • 1 Post By Fernando Pio
Old   August 23, 2006, 14:47
Default Problems with MFIX code and Parallel Processing.
Fernando Pio
I´m use MFIX code (Multiphase Flows with Interphase eXchanges) for to simulate a gas-solid flows in a circulating fluidized bed. The main objective is to investigate the numeric diffusion. Thus, the sufficiently refined mesh is very important.
Then, parallel processing with two machines (PC´s) was prepared (cluster), but the problems are not converging. The convergence is guaranteed if just one machine is used.
Could somebody tell me why the problems are not converging using the MFIX code with parallel processing (of PC´s)?
The operational system is a Mandrake Linux 10.1 and the Intel Fortran Compiler (Fortran 90).
Thanks.
Thanks.
Old   August 23, 2006, 17:10
Default Re: Problems with MFIX code and Parallel Processin
agg
Are you specifying gas as incompressible fluid in MFIX? If so, try to use it as compressible fluid (specify average molecular wt. and gas temperature).
Old   August 24, 2006, 11:44
Fernando Pio
Yes, the gas is incompressible fluid and it can not be changed in MFIX.
Old   August 24, 2006, 12:23
agg
If you specified RO_g, the gas is treated as incompressible. For compressible flow, you should specify Mw_avg (average molecule weight), P_g and T_g in initial and boundary conditions.
Hanzo likes this.
Old   August 29, 2006, 15:33
Fernando Pio
Hi, thanks for your message.
I need to treat the gas as incompressible flow. I think that the divergence was caused by the parallel computing. In my opinion, something is happening with the solution when the problem is divided by the process in the cluster.
The installation this correct one, therefore has convergence when i consider only one machine. According to your experience, it will be that the problem can be in the division of the problem in the cluster? What it could be occurring?
Thanks for all.
Esmaeel likes this.
multiphase solver - parallel processing - GAMG thibault_pringuey OpenFOAM Programming & Development 2 August 27, 2013 23:03
Cyclic patches and parallel postprocessing problems askjak OpenFOAM Bugs 18 October 27, 2010 04:35
is there any parallel code for the famous Lid Driven Cavity flow? gholamghar Main CFD Forum 0 August 1, 2010 02:55
about mfix parallel pan_zh Main CFD Forum 0 November 7, 2009 21:34
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 16:56
