Question about fluid-solid conduction heat transfer contact resistance |
May 6, 2013, 20:12 |
Meimei Wang
Rep Power: 16 |
May I ask is there also a conduction contact resistance for flow-solid conduction heat transfer like solid-solid conduction heat transfer? Or since there is no gas between fluid-solid, the contact resistance is 0?
Best regards, Meimei |
May 7, 2013, 11:39 |
Reza
Rep Power: 17 |
It depends on how clean the surface is. Also, if there is a thin layer on the solid surface (oxidization, paint, chrome coating, ...) that cannot be modeled explicitly for cheap, then you might want to use a contact resistance.
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff | swahono | OpenFOAM Running, Solving & CFD | 10 | October 15, 2018 06:43 |
Heat transfer, convection, radiation, conduction | Sandra H. | OpenFOAM | 1 | March 3, 2010 09:02 |
Non-CFD heat transfer question | Adrin Gharakhani | Main CFD Forum | 1 | November 18, 2000 01:14 |
Solid-Solid Heat Transfer with Contact Discontinuity | Jonas Larsson | Main CFD Forum | 9 | September 10, 1999 16:46 |
