Reynolds number for Wing analysis
Like Tree4Likes
  • 4 Post By Hybrid
Old   January 24, 2013, 00:52
Exclamation Reynolds number for Wing analysis
Solar Spectrum
solar.spectrum is on a distinguished road
hey guys, I would like to know about reynold's number for a wing
I have designed a NACA 4412 wing which has wingroot = a , wingtip = b and winglet tip = c (a,b,c are any integers or decimals)
please tell me the formula of calculating D for the eqn of reynolds number = \rhoVD/\mu
additional info : Wing taper ratio = 0.3 , sweep and sweepback angle = 37 degree
altitude = 6000m , density = 0.65970 kg/m3, Pressure = 47182.5 Pa ,
Temp= 249.2K , velocity of freestream= 100m/s, viscosity= 0.00001594 N sec/m^2
solar.spectrum is offline   Reply With Quote
Old   January 24, 2013, 07:13
truffaldino's Avatar
truffaldino is on a distinguished road
The definition of Re in this case depends on your purpoces. Do you want to comute Lift, Drag, CM?
truffaldino is offline   Reply With Quote
Old   January 24, 2013, 13:25
Solar Spectrum
yes, I want to calculate lift and drag for different reynolds number as well as Angle of attack
Old   January 24, 2013, 13:32
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
your characteristic length "D" is the one that is meaningful for your problem ... any choice of a lenght is coherent with the definition of a Reynolds number, but if you want that the Re number represents the relative magnitude between convective and diffusive fluxes of the momentum quantity for your problem, then you have to choice properly the lenght..
FMDenaro is online now   Reply With Quote
Old   January 24, 2013, 18:28
What method or sotware are you going to use?
In general, single reynolds number fits only for calculation of 2D airfoil. In your case the analysys should be more sophisticated, unless you are going to have a rough estimation.
Tell us more details.
Old   January 28, 2013, 11:57
A.D.E is on a distinguished road
For a 2D wing (airfoil) you can use your chord length to calculate the value of Re!! If you have a tapered 3D wing then the Re will vary at the different locations. You can however calculate an average Re based on your average chord length. A more in-depth analysis can be obtained at:
Fundamentals of Aerodynamics SI by John D. Anderson
And/or
Aerodynamics for Engineers John J. Bertin, Russell M. Cummings
A.D.E is offline   Reply With Quote
Old   January 28, 2013, 12:51
Ali
Hybrid is on a distinguished road
You have to compute the "Mean Aerodynamic Chord" and use that as a characteristics length "D" in Reynolds number formula. The formula for MAC is:
MAC = A-(2(A-B)(0.5A+B) / (3(A+B)))
here, A : Root chord of the wing
and B: Tip chord of the wing
This equation for the straight-tapered wing.
Hope this solves your problem.
Best Regards
Ali
Hybrid is offline   Reply With Quote
Old   July 8, 2015, 12:48
Radwanma
Radwanma is on a distinguished road
Dear Ali;
Can we use the previous equation for a Twisted blade as well?
Thanks,
Radwanma is offline   Reply With Quote
Old   July 8, 2015, 13:06
Ali
Yes. You can.
Best Regards
Ali
aerofoil, wing tip
Applications of Reynolds Number Nadeem99 Main CFD Forum 0 December 10, 2012 03:10
Particle Reynolds number calculation in Lagrangian tracking? jiejie OpenFOAM Running, Solving & CFD 5 July 6, 2012 05:47
CFX Solver Reynolds Number haider760 CFX 2 March 4, 2012 23:05
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 10:01
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
