Fortran code for laminar flow around naca0012 airfoil
Like Tree3Likes
  • 1 Post By agd
  • 1 Post By Umuteng
  • 1 Post By agd
Old   December 5, 2012, 07:44
Post Fortran code for laminar flow around naca0012 airfoil
Kianoosh
kianoosh_py is on a distinguished road
Hi Guys
I need the FORTRAN code with this features: a FORTRAN code for predicting the lift and drag coefficient in laminar flow around naca0012 airfoil.
I need this code for my master thesis and i should develop this code , but for starting i really need a clear code.
kianoosh_py is offline   Reply With Quote
Old   December 5, 2012, 10:42
agd
agd is on a distinguished road
If you are using structured grids, try ISAAC. It can be found at sourceforge.net.
kianoosh_py likes this.
agd is offline   Reply With Quote
Old   December 6, 2012, 07:09
Umut Can
Umuteng is on a distinguished road
viscous or inviscid flow? and compressible or not?
Umuteng is offline   Reply With Quote
Old   December 7, 2012, 13:18
Kianoosh
thx, yes i use structurd used, but i found two code on sourceforge.net by follow setails:
1.
Isaac Hardcore simulation, not for pussies.
0 weekly downloads
Last Updated: 2011-04-20
2.
I.S.A.A.C.S. I.S.A.A.C.S. Interactive Structure Analysis of Amorphous and Crystalline Systems is a cross-platform software developed to analyze the structural characteristics of three-dimensional models built by computer simulations.
23 weekly downloads
Last Updated: 5 days ago
100.0% recommended
which one is recommended.
Old   December 7, 2012, 13:20
Kianoosh
thx for your response. i need a viscous and incompressible code for laminar flow around an naca 0012 airfoil.
Old   December 7, 2012, 13:35
agd
Try this link
http://isaac-cfd.sourceforge.net/
Old   December 7, 2012, 19:39
Kianoosh
thx a lot , i found it but i can't found how to run it. this code have several errors on Microsoft power station compiler, about 60 errors.
did u use of this code before or can you help me to run the code?
Old   December 7, 2012, 20:13
Kianoosh
The ISAAC code is prepare for using in the Linux, i guess. I using windows 7 32bit there is any way to use this on windows7.?
Old   December 7, 2012, 23:38
agd
You could try installing cygwin on windows and use the gcc/gfortran compilers that are included in cygwin. I have only built it under linux.
Old   December 8, 2012, 06:46
Kianoosh
dear agd, i use the user guide for ISAAC and use the cygwin, i use the instruction as follow:
% cd
% mkdir isaac
% cd isaac
% mkdir src
% cd src
% tar -xvf isaac.tar.gz
% tar -xvf wsmake.tar.gz
% make
but when enter the % make, i got this error:
-bash: make: command not found
in the directory the file makefile is exist and i try % makefile and got that error again. do you know whats is wrong?
Old   December 9, 2012, 05:14
Rami Ben-Zvi
Rami is on a distinguished road
kianoosh_py,
I am not familiar with both isaac and cygwi, however my guess is the % is simply the system prompt. Try entering, e.g., cd rather than % cd.
Good luck,
Rami
Rami is offline   Reply With Quote
Old   December 9, 2012, 05:23
Kianoosh
Originally Posted by Rami View Post
kianoosh_py,
Good luck,
Rami
thx dear rami, of course i don't use of %, i write here just to show the command prompt as a symbol.
Old   December 9, 2012, 15:48
agd
Is the error because the make utility is not installed, or is it indicating that the makefile cannot be found? It could also be indicating that you need to execute the make command within a bash shell under cygwin.
Old   December 9, 2012, 15:58
Smile
  #14
Kianoosh
and what should i do?
let's check the make utility is installed or not. how can i check it?
Old   December 9, 2012, 16:50
cfdnewbie
cfdnewbie is on a distinguished road
easiest way: man make
but my friend, just a friendly suggestion: why don't you google these kind of questions? it will give you your answers more quickly, and prevent the cluttering of the thread!
cfdnewbie is offline   Reply With Quote
Old   December 19, 2012, 12:00
Kianoosh
did any body have GHOST code (from Kentucky University)?
and or CFLD3D Code (http://cfl3d.larc.nasa.gov/)
Old   December 19, 2012, 12:51
agd
CFL3D has an easy-to-follow request process to obtain a copy of the code, if you are legal resident of the US and residing in the US. That would be the proper channel to pursue CFL3D. If that is not an option for you, then you should seek other open-source software.
Old   December 29, 2012, 10:24
Richard Ren
wtffqbpl is on a distinguished road
Hi Guys
it's easy to write a fortran code with these features, any cfd book can helps you write this code
wtffqbpl is offline   Reply With Quote
Old   July 21, 2015, 06:22
Dr Gurubasavaraju
gbrajtm is on a distinguished road
Hi All,
i am beginner to CFD. I wanted to write a CFD code for laminar incompressible fluid flow between two plate, The fluid is Magnetorheological fluid which has nanoparticles.
Could you please provide information on, which language is suitable and software to run the code?
Please provide one simple code which i can use as reference or the any link which provide it.
Thanks in advance.
gbrajtm is offline   Reply With Quote
Old   September 13, 2015, 07:19
adhi makayasa
makayasa is on a distinguished road
hi Richard Ren
Can you help me , how do I make a Fortran code for airfoil ? Thank you for the help
makayasa is offline   Reply With Quote
is there any parallel code for the famous Lid Driven Cavity flow? gholamghar Main CFD Forum 0 August 1, 2010 02:55
potential flow vs. Euler flow curious ... Main CFD Forum 23 July 21, 2006 08:40
Simulating flow past airfoil with different AOA Quarkz Main CFD Forum 2 January 6, 2006 11:56
Simulating NACA0012 for inviscid flow. Stan Main CFD Forum 2 May 13, 2005 15:22
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
