September 11, 2012, 10:10 |
"3" phase flow, modeling a toilet
SandeSeb
Rep Power: 14 |
Hello users,
I´m relative new in the CFD topic, nevertheless I got the job to investigate the flushing of toilets. My questions are: Is it generally possible to simulate the flushing of toilets including solid parts (feces)? This would be a "3 phase" problem (water, solid and air at the surface), in my opinion. Which program would you suggest for solving this problem? I have solutions from CD Adapco, Ansys, CF Design and Mentor Graphics in my eyes. Also the program should have an interface or the possibility to use CATIA V5 models. I think, this is a tough job, isn´t it? Thank you in advance for your help. Best regards Sebastian |
September 13, 2012, 02:57 |
SandeSeb
Rep Power: 14 |
Hi again,
has no one an idea? Or just some hints for me on which points I have to look by choosing the software. Thanks Sebastian |
September 13, 2012, 04:00 |
Joern Beilke
Rep Power: 20 |
I would try it with a particle based solver. You might check xflow.
http://www.youtube.com/watch?v=Se4v-QRWtYA http://www.youtube.com/watch?v=aCz8zt-V-TM |
September 17, 2012, 03:17 |
SandeSeb
Rep Power: 14 |
Hey there,
thank you for this hind. I will contact them. Best regards Sebastian |
October 30, 2012, 03:37 |
flow3d may give you answer
October 30, 2012, 14:50 |
Thiago Parente Lima
Rep Power: 15 |
You could adopt the diarrhea hypothesis, then you would eliminate the solid issue.
Sorry, just kidding. |
October 31, 2012, 16:56 |
Erik
Rep Power: 23 |
Wouldn't you rather conduct real world experiments instead of simulations?
October 31, 2012, 22:08 |
Ahmed
Rep Power: 18 |
Previous investigations suggest that it is a 2 phase flow,
Google using the following search criteria "slug flow Toilet flushing cfd" good luck |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Which software for modeling viscoelastic properties in a two phase flow? | michaelb | Main CFD Forum | 9 | February 17, 2011 16:27 |
Two phase flow with condensation | Sunnie | FLUENT | 0 | May 31, 2009 11:02 |
low speed compressible two phase flow?? | cat | CFX | 0 | November 15, 2005 08:59 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
