How to plot Cp Vs X/c
Like Tree1Likes
  • 1 Post By aaron chand
Old   July 24, 2012, 10:56
Default How to plot Cp Vs X/c
Abhipray Jain
abhiprayj is on a distinguished road
I am trying to plot Cp Vs x/chord ... I tried to get the data from fluent but im not able to plot it .. I think i got the wrong data ... I went to XY plot and took headsail and headsail shadow and write the file and after opening it on excel i plot the graph which is wrong .. same i did for mainsail and mainsail shadow....plz help me its important .. moreover .. i saw in many other thesis .. their y axis says Cp and x axis says x/c but on x axis values are 0, 0.2, 0.4, 0.6, 0.8, 1.0.
whereas if i plot same thing on fluent v6, it shows me somewhat right graph but with negative values of Cp on the y axis .. im very confused plz help me...
abhiprayj is offline   Reply With Quote
Old   March 28, 2017, 03:58
Talking
Aron Chand
aaron chand is on a distinguished road
Originally Posted by abhiprayj View Post
Cp is pressure coefficient and x/c also known as x/chord is; x=x coordinate distance of the specific point or tap from the leading edge, c=chord length. So if your point one is 2mm from the leading edge and your chord length is 100, therefore your x/c value is 2/100 i.e. 0.02. Note that the max value of x/c is 1 because at 1, x=c.
Different airfoils with different angle of attack will plot different graphs. Always know the Cp value can never exceed Positive 1 because when Cp=1, that is the stagnation point and at that point the velocity of the particles will be infinitesimally small or approx. zero. But it can never be practically zero on the dot because this is a dynamic system. There is a MS-Dos program made my MIT, its called XFOIL. LEarn its command, and it can tell you the exact graph for most of the airfoil at any angle of attack
CFDnoobz likes this.
aaron chand is offline   Reply With Quote
Plot on a curve Monica FLUENT 1 July 11, 2012 01:24
How to plot xy-Y plot of certain nodes maple2012 FLUENT 0 November 5, 2011 11:00
A girl fail to plot velocity profile when mesh changes + Wall function asherah STAR-CCM+ 0 February 19, 2010 18:45
Transfer low-res graphic file plot to excel plot quarkz Main CFD Forum 3 April 9, 2009 14:54
graph plot anindya Main CFD Forum 2 September 17, 2003 13:00
