"PROPER ORTHOGONAL DECOMPOSITION"
Like Tree3Likes
  • 3 Post By Enougu
Old   December 5, 2005, 01:56
Default "PROPER ORTHOGONAL DECOMPOSITION"
dpshaka
DOSE ANY BODY KNOW THE DETAIL OF THE "PROPER ORTHOGONAL DECOMPOSITION", I HAVE REVIEWED A LOT OF PAPERS ,BUT I STILL CAN NOT UNDERSTAND THE DETAIL OF THE NUMERICAL process of "POD".
IF SOME ONE IS FAMILIAR ABOUT "POD" , PLEASE HELP ME / REGARDS
Old   December 5, 2005, 21:49
Default Re: "PROPER ORTHOGONAL DECOMPOSITION"
Peter Attar
Essentially you collect snapshots of the solution vector at various points in time for represented "forcings". You collect these into a matrix Q and then perform a singular value decomposition on it. You then say that the POD modes are a linear combination of the snapshot vectors(snapshot method of POD) so that the modes can be represented as [R]=[Q][V] where Q is the snapshot matrix and V are the right singular vectors. For a more detailed explanation on this look for papers by Thomas,Dowell et al and Beran et al.
Peter
Old   December 8, 2005, 14:28
richard
You may want to check the following link:
http://dissertations.ub.rug.nl/FILES...azemier/c2.pdf
It doesn't seem to be too badly explained by this guy. For further literature, look for the method of Sirovich, which is an approximation of the continuous (aka. classic) POD.
Best regards, Richard
Old   December 11, 2005, 05:01
dpshaka
thank you for your feedback, but would you please give me some detail information about the numerical procedure of the POD .
regards.
Old   December 13, 2005, 19:35
richard
Hopefully I got you right and you are looking for an implementation? Below you find a kind of step-by-step example (I am sorry for the looks. "_" and "^" are used for indecies and (f,g) is a scalar product):
N vector fileds u_k=u_k(t_k) (provided by e.g. PIV measurements) at different times t_k, k = 1...N.
u_k is representet by e.g. 2 matrices: u-component and v-component of velocity u_k, both of the size m x n.
Snapshot method by Sirovich: 1) create a vector (one dim. array) for each vector field e.g. U=[u_11,v_11,...u_mn,v_mn], where m and n are the dimensions of the vector field. The vector U has the size of 1 x 2nm.
2) Calculate the 2-point cross-correlation matrix Q: Q_ij = 1/N (U_i,U_j).
3) Solve the eigen value problem "Q q_i = lambda Q" to find the eigen vectors q_i. There are N eigen vectors q_i (i = 1...N) with the size of 1 x 2mn.
4) Calculate the orthonormal base, phi_i, (aka. eigen modes) of the POD: phi^i = SUM[n = 1...N](q_n^i U_n).
5) Reconstitute a vector field in the new orthonormal base: U_new = SUM[i = 1...N]((U_old,phi^i)phi^i).
I hope this will help you.
Regards
Old   December 13, 2005, 22:31
dpshaka
Dear richard:
Thank you very much for your feedback.It gives me so much help.
I have seached a lot of paper, but the method that they used is different from what you have said. they all solve a eigenvalue problem in a integral equation form.
so would you mind give me your email address, i still have some problem about this POD technique.
ztdep@163.com best wishes
your DP
PRC XJTU
Old   December 17, 2005, 02:38
ztdep
Dear richard:
i have send a email to you ,have you received it ?
regards?
yours
Old   June 12, 2019, 10:42
Post Thread update
Jack A. Hanson
Enougu is on a distinguished road
Dear future user, the previous link to Willem Cazemier's work is dead, I think I've tracked down the document at it's new home:
https://www.rug.nl/research/portal/files/3214637/c2.pdf
Enjoy!
arjun, arashgmn and allanZHONG like this.
Enougu is offline   Reply With Quote
Proper orthogonal decomposition of turbulent flow with k-e Blob Main CFD Forum 0 June 5, 2009 10:32
POD or ROM (Proper Orthogonal Decomposition) mike Main CFD Forum 8 June 10, 2006 04:39
Snapshot Proper Orthogonal Decomposition (POD) Mehmet SEN Main CFD Forum 7 May 19, 2006 13:38
On Proper Orthogonal Decomposition R.D.Prabhu Main CFD Forum 0 March 15, 2000 18:31
Orthogonal curvilinear coordinates Rudolf Pfeiffer Main CFD Forum 6 December 10, 1998 11:20
