Carbuncle phenomenon for blunt body flow on unstructured grid
Like Tree2Likes
  • 1 Post By praveen
  • 1 Post By SangeethCFD
Old   June 13, 2012, 02:03
Default Carbuncle phenomenon for blunt body flow on unstructured grid
Praveen. C
praveen is on a distinguished road
Roe scheme is known to suffer from carbuncle phenomenon for blunt body flows like hypersonic flow over a cylinder. I have seen numerical results on structured grids that exhibit carbuncle. But has anybody found this occurring on unstructured grids. I am trying mach=10 flow over a cylinder on triangular grids with first order Roe scheme without any entropy fix, and am unable to get any carbuncle. I know that it may not occur all the time; changing the grid can make it go away. But is there a reliable way to induce it on triangular grids.
aerosayan likes this.
praveen is offline   Reply With Quote
Old   July 30, 2015, 06:38
Smile Carbuncle on unstructured - a gray area
Sangeeth
SangeethCFD is on a distinguished road
Dear Praveen,
I have been studying numerical shock instabilities for over an year now. As such I have not come across any papers reporting or even attempting to produce carbuncle on unstructured grid. [1] suggests that carbuncle forms only on grids with preferred direction and any anisotropic grids (like unstructured) may not form it at al. However, [2] shows that a triangulated structured grid may produce carbuncle.
Sorry that the reply is so late. I happened to see you post only recently. Did you come across any such reports of carbuncle on unstructured grid since you posted?
References
[1] = 'Dissipative mechanism in Gudonov type schemes', IJNMF, 2001, vol 37
[2] = ' Nearly all speed, stabilized, time accurate upwind schemes on unstructured grid', AIAA, 2010, vol 48.
SangeethCFD is offline   Reply With Quote
Old   July 30, 2015, 11:11
Praveen. C
I could not get carbuncle on purely unstructured grids. If you use structured grids which are triangulated, you may get carbuncle. As you said, the shock has to be aligned with the grid lines to see this.
[ANSYS Meshing] Simple Symmetry Mesh Question - Flow around Bluff Body Matlab69 ANSYS Meshing & Geometry 20 April 23, 2012 10:55
Modeling 3D external Flow over a streamlined body. gacins Siemens 4 January 22, 2012 06:46
Unstructured grid problem - Laminar flow pipe Roby FLUENT 0 January 12, 2006 06:54
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
