Coal combustion injection properties
Like Tree1Likes
  • 1 Post By bahramnourani
Old   February 24, 2012, 16:44
Default Coal combustion injection properties
semo is on a distinguished road
I am trying to model Coal combustion in a furnace with Fluent. I am using nonpremixed model and coal calculator. Coal powder+air mixture is introduced to the furnace by the burner. My question is when I specify the injection for the coal, the mass flow is for the coal not for the air+coal mixture, right? I specify the air flow in the inlet BC.
Lets say I have 10 lb/sec coal and 15 lb/sec air going into the furnace:
Burner inlet BC mass inlet : 15 lb/sec
Burner inlet BC mixture fraction :10/(10+15)=0.4
Coal injection mass flow :10 lb/sec
Coal injection velocity : (calculated from coal density, inlet area and mass flow)
Is this the correct approach?
Thanks in advance for any comments...
semo
semo is offline   Reply With Quote
Old   February 25, 2012, 10:18
Default hi
shoeb khan
shk12345 is on a distinguished road
hi
may be i may be wrong but what i think this should be solved in the follwoing way
take velocity inlet for coal and air not mass flow inlets
second the phase volume fraction should be on volume basis not on the mass basis.
regards
shk
shk12345 is offline   Reply With Quote
Old   February 28, 2012, 12:33
Thank you for your reply. What about the coal+air mixture? Coal particles are transported with air. I would think since coal is defined by injection on inlet surface seperately the inlet BC should have the air flow only (non-premixed combustion).
Old   March 10, 2012, 23:08
jorge
Vorch is on a distinguished road
hi,
I think (and I may be wrong) that the coal velocity its only the velocity from the air that transport the coal (so you have to calculate it with de air density at the respective temperature, surface and air mass flow), and the coal mass flow its only for the coal.
Im right now modellating a tangentially fired pulverized coal boiler, and for BC for the air in the same surface that the injection, I put velocity inlet and specify 0.23 for de mass fraction of O2. That will modelate de primary air.
I hope that this helps you,
Vorch is offline   Reply With Quote
Old   June 13, 2013, 04:54
Bahram
bahramnourani is on a distinguished road
Dear Semo
I define the excess air of fuel by selecting a suitable mass flow of air at the boundary condition of the Fluent software,but I see that by increasing the excess air of fuel the maximum temperature is increased!??
I expect that the adiabatic flame temperature is dropped down by increasing the excess air of fuel.
Please guide me that how can I define the excess air of fuel at the non premixed combustion model.
Thanks
Bahram
bahramnourani is offline   Reply With Quote
Old   November 20, 2013, 03:07
Nasharuddin MJ
NasharuddinMJ is on a distinguished road
hi bahram
i'm not sure whether u have solve the problem with excess air. just want to share with u guys. u can start with stoichiometry. then increase as you need with reference to your stoichio. you can double check with gas species at outlet. Normally with excess air, both CO and OH will fully combust and small portion of O2 (depend on your %e.a).
If u increase excess air and the temp goes up, check both CO and OH in your combustion chamber whether they have fully combust. if not, that just mean that u provide more O2 to complete the combustion.
NasharuddinMJ is offline   Reply With Quote
Old   November 20, 2013, 15:03
Bahram
Hi NasharuddinMJ
Thanks for your replying.My fuel was solid, and the combustion of solid fuels should be injecteded at Fluent.My mistake was that I didn't inject my solid fuel.
Thanks
Old   April 29, 2014, 10:11
Maaz Ul Mosaid
maazulmosaid is on a distinguished road
Are you using 3d or 2d? which meshing type you used?
please help me . i am in real need
please share your experience with me
which model you used?
maazulmosaid is offline   Reply With Quote
Old   April 30, 2014, 12:20
Bahram
Hi maazulmosaid
My geometry was symmetry, then I used a 2d model. I think that starting with a simple geometry will reduce your computation time wonderfully, and let you correct the mistakes of your boundary conditions in a short time.
I could get rapid convergent with structured quadrilateral grids which was meshed by gambit automatically.
I think that the combustion model which u want to choose for your simulation depends on to the kind and phase of your fuel(solid,liquid,gas) and the state that it mixes with air.
I think that all of the combustion models can give u reasonable results.When i used species transport combustion model the maximum temperature was higher than the maximum temperature which was resulted by nonpremixed combustion model.
I think that nonpremixed combustion model is suitable when we want to consider equilibrium reactions.
Examples of Ansys Fluent will help u.
Bahram
adna likes this.
Old   April 30, 2014, 13:22
Thansk Behram for replying
Have you done 3d coal combustion. I am working on 3d coal combustion
My chamber is 400 cm in height and 8 cm in diameter
My problem is that volatile conv and char conv is very low and i am not getting converged solution
Can you please help me in this matter
my email is
maazulmosaid@hotmail.com
Old   May 2, 2014, 12:03
Default Similar problem
  #11
Syed Muhammad Khubaib
khubaib_syed is on a distinguished road
I am attempting to do a tutorial that you posted on another post
http://wenku.baidu.com/view/49fa818ecc22bcd126ff0c14
I am getting the error of mass imbalance in reaction-1 stociometery
my email is
khubaib_syed is offline   Reply With Quote
Old   April 25, 2016, 15:19
Default Validation Paper
  #12
shailin
shai102 is on a distinguished road
HI all , i need a basic cal combustion paper for validation purposes. i am a bsc graduation student. anyone a suggestion? i dont already know much about this subject thats why im asking for advice?
shai102 is offline   Reply With Quote
Old   May 16, 2017, 20:40
Default coal combustion
  #13
nadia
adna is on a distinguished road
Bahram
hello,
i work with coal combustion,non premixed combustion and dpm but the poblem i have in species result just co2 and H2O i dont find ho,co,,, i dont know where is the poblem,help me please if u have any idea
adna is offline   Reply With Quote
Coal Combustion simulation Yogesh FLUENT 2 March 20, 2024 14:19
Problem on EDC model for coal combustion lei FLUENT 4 September 3, 2015 10:39
coal injection properties in actual reactor saifulraju FLUENT 0 September 30, 2010 07:04
Coal combustion and ash reaction kinetics sega Fluent UDF and Scheme Programming 0 January 21, 2010 09:05
moisture in coal combustion Sheng FLUENT 3 June 15, 2003 20:43
