January 1, 2012, 08:40 |
tetra hexa mesh
hamid
Rep Power: 16 |
Hi Guys,
i have to model a pipe in 3-d but with tetra mesh it seems that i have to dense it very very much to make the solution independent of grid, do u think in hexa mesh it radically improves? for grid independent study what is the role of thumb for the criteria to use, in terms of which parameter is better to be measured , how do u measure it (e.g. weighted average etc) and how much difference between denser and coarser mesh is acceptable? thank you hamid |
January 1, 2012, 11:22 |
#2 | |
January 3, 2012, 20:05 |
Rep Power: 15 |
The idea when you are using hexa compare to tetra is to align your cells with the flow pattern. In this case, there is less information diffusion between the cells.
Now, in Fluid mechanics, everybody knows that the main pressure gradient is in the boundary layer, close to the wall. Hexa mesh allows you to refine in the boundary layer thickness and to strech the mesh in the flow direction. Hexa mesh is anisotropic. At the inverse, tetra mesh is an iotropic mesh. Means, if you want to refine in the boundary layer then you need to refine in the 3D dimensions (lot of cells). 2 "good" points: Hexa needs less cells and get less diffusion if flow aligned with the cells 1 bad point: it is not always easy to create an hexa mesh. Tetra with never be as good as hexa |
April 11, 2012, 12:49 |
Mesh Independent solution
Rep Power: 15 |
I am using hexa mesh for pipe flow but for all my element numbers the solution is grid independent. Am modelling turbulent flow with standard wall functions. When I change the distance from the wall using inflation layers the solution remains the same as previous one! The results seem sensible.
April 11, 2012, 13:13 |
Rep Power: 15 |
Fine,
If you obtain the same result whatever is the mesh, then it is perfect. Find the coaser mesh you can to reduce time consumption in the futur. Which CFD code are you using? Depending on the turbulence you are using, all the mesh are not recommanded. The mesh size is based on the Y+. You can decomposed the boundary layer in 3 layers: Viscous sublayer Outlayer and in the middle the log layer Basically Y+=1: sublayer linear layer u+=y+ 30<Y+<300:log layer You have to know where are valid your turbulence model and the wall function you are using. |
April 12, 2012, 12:23 |
#6 | |
banty
Rep Power: 14 |
For the same number of cells in hexahedral and tetrahedral mesh, average cell centroid distance in tetrahedral mesh is larger compared to the hexaherdal mesh. thats why tetrahedral mesh need more no of cells to be grid independence. Anyway hexahedral mesh gives more accurate result compared to tetrahedral mesh it does not matter which solver u are using because pure orthogonal quality of tetrahedral mesh. Quote:
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 07:21 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 07:42 |
[ICEM] Hexa Mesh Smoothing | Jules | ANSYS Meshing & Geometry | 6 | December 4, 2010 19:00 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
HELP! TETRA and HEXA boundary | sunlight007 | Siemens | 6 | August 6, 2004 07:15 |
