set BC for fluidized bed
Like Tree2Likes
  • 1 Post By sangramroy
  • 1 Post By rayolau
Old   December 2, 2011, 22:05
Post set BC for fluidized bed
NAD
NAD is on a distinguished road
hi. i tried to make fluidized bed simulation 2D.the geometry is simple:a cylinder 2D with inlet and outlet. BC are defined as flow:
Inlet at the bed bottom is designated as Velocity Inlet boundary conditions for both the gas and solid phases. The boundary condition at the top of the bed is a pressure boundary fixed at a reference value (atmospheric).
Solids are free to leave if entrained and then return to the computational domain from the bottom inlet with a same mass flux.
how i can fix this in fluent??? i mean this condition ''Solids are free to leave if entrained and then return to the computational domain from the bottom inlet with a same mass flux.''
thanks
NAD is offline   Reply With Quote
Old   December 2, 2011, 23:52
Default Re
shoeb khan
shk12345 is on a distinguished road
hi
nice question but i have no idea.
May be you can generate a udf for mass flow inlet in which the inlet mass flow can be computed from the mass flow from the outlet.Give the inlet mass flow of the solid same as the mas flowing out of the system.
Try it i hope that works.
SHK
shk12345 is offline   Reply With Quote
Old   December 5, 2011, 04:33
Sangram Roy
sangramroy is on a distinguished road
are you trying to simulate a circulating fluidized bed? If so, in 2D you have a mention a certain solid velocity at the inlet assuming that they are always constant .
sangramroy is offline   Reply With Quote
Old   December 6, 2011, 21:39
NAD
hi. shk, sangramory thanks for your reply.
shk, i will try UDF and let u know.
sangramory, yes I'm trying to simulate CFB. more exactly. the riser of CFB without the loop of return (i.e. cyclone, standpipe, feed device...) for this i need an adequate BC which can replace the loop of return.
Old   September 19, 2012, 06:23
prishor p k
prishor is on a distinguished road
I am doing my project in simulation of bubbling fluidized bed. i had made 2D geometry with meshes. Now the problem is that i have to include the bed material(sand) with initial bed height to the geometry before the simulation. Can anyone help me in this regard as I am new to FLUENT.
prishor is offline   Reply With Quote
Old   September 19, 2012, 12:28
Sangram Roy
You have to 'patch' the regoin where you would like to have sand. The steps are as follows:
1) Adpat->Region-> Options-Inside-> Shapes-Hex-> Input coordinates( specify the coordinates to mark the region where solid is present)->Mark
To check whether the region is correctly is marked, go to Manage-> select region -> Display.
A new windows pops up showing the region marked.
2) Initialize the system. Then follow:
Solve->Initialize->Patch-> Select solid phase-> select volume fraction under variable-> insert a value of volume fraction under 'value' -> select the region under 'Registers to patch'-> Patch.
Its done.
To check the correctness before starting the simulation, you can check the contour plots of solid volume fraction. Please remember, don't initialize again after patching.
ramakant likes this.
Old   September 20, 2012, 01:55
prishor p k
Thank you Sangram..thank you very much...its a valuable information for me...once again thannxx..
regards,
prishor
Old   September 20, 2012, 02:09
prishor p k
Dear Sangram,
May I have your mail ID so that I can contact you for any clarifications.
Thanks and regards,
Prishor P K
Old   September 26, 2012, 10:39
prishor p k
Can anyone help to get some tutorial about analysis of Fluidized Bed Gasifier in FLUENT..
Please help me as I am new to this area
Old   September 28, 2012, 04:24
rayolau
rayolau is on a distinguished road
Hi!
I need do a patch for create a sand bed. It`s posible utilice patch and injections?
Regards,
Laura
rayolau is offline   Reply With Quote
Old   March 8, 2016, 03:56
Default a question
  #11
Ramin1985 is on a distinguished road
Its done.
following this order, the region where is patched by sand will be marked, but how about the solids that are intended to fluidized? I mean how can I specify the region above the sands involving the solids at the initial state?
I have patched the region for the sands and I ended up with such result:
u (inlet air): 0.3 m/s
bulk density of solids: 100 kg/m3
run time: 1s
does it mean that the sands are also fluidizing?
Ramin1985 is offline   Reply With Quote
boundary condition, fluent, fluidized beds
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Bed lifting Fatnes CFX 1 August 22, 2009 07:00
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
Problem in installation of OpenFOAM sachin OpenFOAM Installation 7 January 22, 2008 02:40
Env variable not set gruber2 OpenFOAM Installation 5 December 30, 2005 05:27
