December 2, 2011, 06:46 |
Boundary Layer Across the Inlet of Nozzle
Rep Power: 15 |
I have a converging-diverging nozzle with 'pressure-inlet' and a 'pressure-outlet' and are using a no slip condition at the wall.
At my inlet, I have a velocity profile across it, indicating that I have some sory of boundary layer as I have a velocity profile across the inlet. But, as it is the inlet, I should not have a boundary layer because there has not been any boundary layer growth or anything. Does any one know why this would be the case? The image shows what I mean. The x axis represents the y distance away from the centreline. There is a velocity profile when there shouldn't be one. I have also attached the velocity vectors at the inlet. Thanks in advance! |
December 2, 2011, 07:02 |
hi
shoeb khan
Rep Power: 15 |
Hi
Just try to use a very very fine mesh at the corners if you want a boundary layer at that place. Thanks SHK |
December 2, 2011, 07:07 |
Rep Power: 15 |
I meant there should not be a boundary layer at the inlet, but my case shows there is a boundary layer there because of the velocity profile. I want to find out why there is a velocity profile there, when there shouldn't be one.
Thanks |
December 2, 2011, 23:43 |
Hi
shoeb khan
Rep Power: 15 |
The problem is that at inlet the flow is developing and it requires some time to come under the state of fully developed state.
Hence during that transaction period there has to increase of velocity . There is no slip condition at the walls. Hence the velocity there is 0.But at the center of the pipe velocity has to maximum. Hence there should be a velocity profile. I hope this may help you. SHK |
boundary layer, fluent, inlet |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 | prashanthreddyh | ANSYS Meshing & Geometry | 1 | December 20, 2011 01:35 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
compressible flow in a counterflow nozzle | d.vamsidhar | FLUENT | 0 | November 24, 2005 02:45 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 20:23 |
